wolfe race craft crotch strap bracket (f body)
fits any 1982-2002 f body.
bolts in on top of factory seat studs so you can have a point for mounting your 5 way harness without drilling into your pride and joy.
complete bolt on and go. no drilling.
painted satin black.
$30.00
$30.00
2 front lines.
20" overall length.
steel fittings
3an with 90 degree fittings.
factory style female fitting on the other end. fit 84-92 f body, should also fit 93-02 f body with factory lines or any other car using a metric flare.
30 shipped.
20" overall length.
steel fittings
30 shipped.
gm 15165400
removed from 2002 ext cab, short bed
its the big forged spicer yoke on the end. not sure if its for the 4l80 or it goes into the transfer case for a 4wd. could easily be swapped out.
use the tube and shorten it, or buy it for the yoke.
this one is 150+ bucks new.
driveshaft measures 68" center of u joint to center of u joint.
driveshaft priced from gm is just over 450 bucks.
50.00+shipping
50.00+shipping
