243 Heads, Pistons, Rods, Etc. Tons of Engine, Braking and Suspencion Parts with Pic
The Prices are NOT FIRM so If something seams too high in price, Let me know and we'll work it out !!!
Also look at My Sig for the links to the rest of my Sales !!!
Prices are plus shipping and 3% Paypal.
243 Heads with Valves and Yellow Springs - SOLD !!!
Hollow LS6 valves Like NEW (they cost over $400) - for Only $200 SOLD !!!
High Performance Blue LS6 Springs with retainers - SOLD !!! - Good for up to .570 Lift !!!
Brand New Mr. Gasket Exhaust Gaskets Ultra Seal - $23 Shipped !!! I paid almost $35 for them...
New LS2 Timing Chain - $35
Sealed Power 4.030 Pistons with 500 Miles - SOLD !!!
I only have 7 but They are like $60 if you want to buy the 8 one !!!
http://www.rockauto.com/dbphp/mak,CA...ne,5620,Piston
Set of 8 LS2/LQ9 Rods (Full Floating Pins) with 15+K miles - SOLD !!!
26Lbs Injectors - $10 each !!! I only have 7 or $50 for all !!
'00 Rear Calipers 30K Miles - SOLD !!!
'06 Starter with Only 14K Miles - SOLD !!!
LS1 Cable Throttle Body Bracket - SOLD !!!
Modded AirBox - SOLD !!!
Poly Bump Stops NEW (Bought from a member here but never install them) - $50 !!!
LS1 Fans with Low Miles - $99
LS1 Coolant Lines, Intake Bolts (Only 9) and Fuel Rail Bolts - SOLD !!!
LS1 Aluminum Driveshaft - SOLD !!!
FlowMaster 3" Stainless Catback Only $229 !!! I Paid over $500 used few months only
Stock Y-Pipe only 30K miles $39
3" SLP I-Pipe with a CutOut - SOLD !!!
Stock SS Tailpipes / Tips - $35 !!!
Intake Gasket Kit Brand New - $55 !!!
LS1 Main Caps low miles - SOLD !!!
LS1 Roller Rockers $9 each
Oil Pan Tray $20
Perimeter Valve Covers w/Bolts $35
Radiator Hoses $18 Each
Hose to Booster $12
Accessories and A/C Belts Low Miles $34
Trans Support $25
Oil Pan Tray $20
Hose to Booster $12
Trans Support $25
UMI Tubular LCA - SOLD !!!
Throttle Position Sensor $75
97-08 Vette Hawk Competition Pads used for 1 Day but look NEW !!! $95 - Paid Over $130 for them !!!
Hawk Performance's HP Plus disk brake pads are designed for sports cars, coupes and sedans for sport driving in autocross, Solo II and many “track day” applications. Additionally, the Hawk Performance HP Plus Ferro-Carbon compound can take the heat at the track and get you home safely without having to change your brake pads in and out. This compound was designed for the serious street and autocross enthusiast.
Key Features and Benefits of Hawk HP Plus Brake Pads:
-Extremely high friction output
-Suitable for autocross events
-Race worthy for club racing
-Elevated temperature resistance
Stock Font Pads (tons of life left) $45
Many Sets of LS1 Rotors Front or Rear $67 each set "FREE SHIPPING"
Brake Hoses $20
Brake Master Cylinder $45
Brake Lines from Master to the Block - $20 each
ABS Brake Block - $60
Cruise Control Module - $95
Front Pass Spindle $65
10 Bolt Housing with Relocation Brackets Weld in $80
10 Bolt C-Claps Axel holders $15
Emergency Brake Brackets (cut to use with Rel. Brackets) - SOLD !!!
Emergency Brake Cable $25
Upper and Lower Panhard bar - SOLD !!!
LT1 Front Calipers RED with CAMARO on them $75
LT1 Performance Pads $55
Front Drilled LT1 Rotors $75
LT1 Spindles $50 Each
Brake Hoses $20
You have the two ebrake cables that come from the single cable to the actual brake? Its two cables, needed for 98.
I may need that center one too.
Truck latch for a 3rd gen???
IS that price shipped on the driveshaft?
