LS1/T56, head bolts GM & ARP, misc
Since I sold the vehicle this was going in, I have decided to sell this motor and concentrate on my 370 going into the '72. This is an LS1 motor from a 2000 Trans Am with 38,000 miles on it. It comes with all accessories, wiring harness, PCM, sensors, basically everything. Sitting on a pallet now and I can ship.
I'm looking to get $2,500.00 plus the ride.
T56 aluminum driveshaft $75.00
20 New GM head bolts, part number 11519772 (2004 and up), $40.00 shipped
Truck oil pan, windage tray, pickup. $50.00
I have some other stuff off the 6.0 that needs to go too, complete rocker set, crank that needs to be turned, injectors etc. ask, It'll go real cheap.
I will consider trades for stuff I still need
- 4.030 rings (1.5, 1.5, 3.0)
- ARP main studs
- ARP head bolts or studs pre 2004 (don't ask, I'm a dumbass)
- Front accessories (H2O pump, alternator, dampner)
- LS7 lifters (new only)
- Interesting cam for L92 headed 370
PM is the best way to contact me.
Bruce
- ARP main studs
Bruce
New Explorer 8.8 rearend with discs, emergency brake, 4.10 limited slip, calipers. All new never run. I had the long side narrowed to match the short side and the rear is 57.75 inches wide from mounting surface to mounting surface. I was attaching a Checkered Racing four link and can include it, but will also seperate it. $800 or $1200 with four link.
PM me for more info.
Last edited by 72VenturaII; Sep 20, 2009 at 07:57 PM. Reason: Thread merge took out previously posted info
