Garage Clean Out
This is just the start of it sadly.....
ALL PARTS ARE OBO AND HAVE COME FROM A 01 SS CAMARO WITH 72K ON IT.
Stock Headlights $80
Passenger Window $40
Drivers Window $40
Rear Bumper (Black, Good Paint) $60
A4 Transmission Cross Member $25
Dash Brace $10
A4 Transmission Hard Lines $20
Passenger Side Wiper Cowl $15
Drivers Side Rear Wheel Well Plastic Piece $5
Cruise Control Setup $50
Heater Hard Lines/Hoses $25
Drivers Side Inner Hatch Wheel well Plastic Piece $5
Underbody Tunnel Brace $15
Rear Bumper Plastic Brace $25
Panhard Bard with Upper Brace $25
Front Strut $10
Heater/AC Box $35
Fuel Hard Lines/Brake Hard Lines Full Body Length $50
Heat Shields $20
Rear Spring Isolators $15
Full Dash (Cracked) $20
Passenger Knuckle with Hub $35
Window Motors/Tracks $35
Window Weather Striping Tracks $20
T-top Weather Striping Drivers and Passenger Side $40
Serpentine Belt $5
Smog Pump Lines $5
E-Brake Main Cable $8
Door Plastic Noise/Weather Shields Passenger and Drivers Side $10
Rear Hatch Struts $15
AC Dryer $15
Cowl Weather Striping $5
Passenger Window Corner Trim $10
Drivers Window Corner Trim $10
Gas Tank Filler Surround $5
Door Lock Push Rods $10
ABS Block Bracket $10
Rear Body Vent $5
Upper Control Arm Brackets $20
Front Sway Bar Brackets $15
Hatch Pop $8
Master Cylinder Lines $5
Steering Column Brace $5
AC Compressor Bracket $25
Upper Radiator Hose with Power Steering Cooler $20
AC Dryer Bracket $5
ABS Block/Pump $30
Master Cylinder (Two Available) $20 Each
Wiper Motor $15
Misc Hardware (Ask)
Rack and Pinion $80
Torque Arm $30
Full Body Harness $100
Drivers Side Door (No internals Includes Lock, Handle, Hinges) (Black, Good Paint) $40
Passenger Side Door (Complete door) (Black, Good Paint) $65
K-Member with A-Arms $65
Fuel Tank (Pump, Sending Unit, Canister, Plastic Lines) $100
Drivers Side Kick Panel $25
Passenger Side Kick Panel $25
Drivers Side A-Pillar $20
Passenger Side A-Pillar $20
Drivers Side Sail Panel $40
Passenger Side Sail Panel $40
Hatch Plastic Panel $20
Center Console with Lid $100
Passenger Side Rear Panel $15
Drivers Side Rear Panel $20
Two Sony Speakers Round (XS-R1342) $20
Drivers Side Dash Vent $8
Passenger Side Dash Vent $5
Under Steering Column Plastic Panel Support $5
Glove Box $20
HVAC Controls $30
Hatch Release Button $5
Passenger Side T-top Pin Cover $4
Drivers Side T-top Pin Cover $4
Rear Speaker Grill $10
Rear View Mirror $15
Gauge Cluster Surround $15
Jack Cover with Screw $5
Under Dash Plastic Panel (Gas Pedal Area) $10
Sail Panel Foam Support Blocks (two) $5
Rear Shock Upper Foam Covers (two) $5
Standard Antenna Base with Rod $10
Under Carpet Insulation $5
Sun visors (Need Recovering, Good Core) $15
Passenger Under Dash Panel $10
Under Column Hard Cover $10
2001 SS Owner’s Manual Set $15
Hatch Storage Area Door $25
Vent System Piece $4
E-brake with Handle $20
A4 Shifter $20
Delco Amp $15
TPS Controller $25
Tail Light Harness $15
Two PCM Gaskets $5
Two Pioneer Round Speakers (TS-G1642R) $25
Two Sony Speakers (XS-R1642) $20
Center Console Cup Holder Linder $8
Air Box Rubber Seal Flap $4
Tire Hold Down $2
Hood Latch $5
Hood Latch Support $5
Head light top support $2
Two Red Toggle Switches $6
MAP Sensor $12
Brake Booster Hose with Check Valve $6
Fender Support (Upper) $2
AC Dryer Line $5
A4 Shifter Bezel (Has Crack) $15
Passenger T-top $100
98 Z28 hatch has some damage but good tinted glass $20
Third Gen Parts/SBC
82-92 Gas tank brand new $150
Gen I sbc crank 350 $50
82-89 Camaro Spoiler 3 piece $45
82-92 single cooling fan $20
82-89 Camaro gauge cluster 85mph speedometer $30
Hei dizzy (no cap or rotor) $20
2 power steering pulley's 2 grove v-belt press on $5 each
86 hatch glass and deck lid $40
86 hatch glass $30
Drivers Window $40
Dash Brace $10
Front Strut $10
Heater/AC Box $35
Heat Shields $20
Serpentine Belt $5
Smog Pump Lines $5
AC Dryer $15
Rear Body Vent $5
Hatch Pop $8
AC Dryer Bracket $5
ABS Block/Pump $30
Wiper Motor $15
Misc Hardware (Ask)
Rack and Pinion $80
Torque Arm $30
Glove Box $20
HVAC Controls $30
A4 Shifter $20
Delco Amp $15
TPS Controller $25
Two PCM Gaskets $5
Tire Hold Down $2
Hood Latch $5
MAP Sensor $12
AC Dryer Line $5
Third Gen Parts/SBC
86 hatch glass $30
From: Born/Raised North East, MD Lived in VA, NC, MI Back in Yorktown, Va
i might have a LT1 T56 from a 94 Z pm if your interested. unsure exactly of whats wrong with it ill have it to a tranny shop soon hopefully to find out what needs done to it.
I may take the hatch weather stripping. Is it the one that goes around the top part of the glass by the sail panel? Also the rear driver's side plastic is it the one with speakers or no?
The hatch weather striping is the one that runs around the entire hatch area that seals the hatch to the body of the car. The rear drivers side plastic is the one with the speaker in it.
