Lingenfelter TRG-001A 58x to 24x Crank Signal Conversion Module
Old Sep 11, 2009 | 11:49 AM
branndonw's Avatar
Default Lingenfelter TRG-001A 58x to 24x Crank Signal Conversion Module
Lingenfelter TRG-001A 58x to 24x crank signal conversion module. This item was installed but was never run. I pulled the plug on this project before I ever started the motor. For my particular application, it was easier for me to hard wire in the module at the ECM than to route the wiring and use the supplied connectors. I cut the connectors off halfway between the connector and the module. I’ve reattached the connectors using solder and heatshrink tubing, all the wires are still the correct lengths. $150 shipped to 48 states.
Reattached connectors
After connectors have been reattached
Cam sensor extension harness
Old Sep 11, 2009 | 06:28 PM
Spectre86's Avatar
Pm sent. 1st in line pending the pictures. (im at work and photobucket is blocked)
I have an 07 LS2 shortblock that im going to be putting in my 00 vette, so I need it.
What was it used with anyway?
Old Sep 11, 2009 | 07:10 PM
branndonw's Avatar
PM returned.
Old Sep 14, 2009 | 08:38 PM
Spectre86's Avatar
Payment sent today.
PM sent with tracking number
Old Sep 26, 2009 | 01:47 PM
Spectre86's Avatar
showed up today. Looks great. Thanks again Brandon.
