9" 4.30 gears, Suncoast Airbox, AC parts, stock fans, stock MAF, washer res, Dist Blk
Moser 9" 4.30 ring and pinion
-used about 15k, removing to install 3.70's for turbo build
$75
Suncoast Creations Airbox
- added weatherstripping to seal to suncoast hoods, also includes filter and iat sensor
- only issue is bolts that hold down top portion snapped a few years ago, never had an issue as the weatherstripping presses everything together nicely
$100
AC drier
$25
AC Condenser
$40
AC Compressor
- leaks very slowly, takes about 10-12 months to leak out
$25
AC Manifold Line
$25
Stock Electric Fans and Pigtails
$100
Ported Stock MAF
$40
Stock Washer Res
$25
Stock Valve Springs off 317 heads
$20
DB LINK 0 Gauge distribution blocks
$50
i have the batt terminal and two dist blocks on the right side of the pic, ill take an actual pic of mine tomorrow
http://www.dblink.net/images/product...DZ_2_large.jpg
all prices are plus shipping
thanks
$75
$100
AC drier
$25
AC Condenser
$40
AC Compressor
$25
AC Manifold Line
$25
$100
Ported Stock MAF
$40
Stock Washer Res
$25
$20
$50
thanks
considering all the piece from suncoast is is a stock lt1 radiator shroud which can be found anywhere, i wouldnt exactly call it worthless, and the kit from suncoast is $350 not $275.
thanks for your input though...
