Race Car part out sale
Email me: gen3_tuning@yahoo.com if you are serious, I do not check this board often.
Stock 2003 LQ4 Short block
70,000 Miles
15 Track passes on race setup
In good shape
Asking $400
B&M TH400
4400 8” Stall
Transbrake
B&M Deep Pan
CSR Trans Shield
B&M Trans Cooler & Lines
Autometer Trans Temp Gauge
BMR TH400 X-Member
ES Trans Mount
Asking $950 SOLD to Tom
GMPP Chevrolet Valve Covers
Both covers have breather port
w/Coil Relocation setup
Asking $250 SOLD to Tom
1998 Camaro Z28 (Roller Body Only)
BMR Subframes
10-point Jeg’s Weld-In Roll Cage
Fully gutted
Sumped metal tank
Aeromotive A1000 Fuel Pump
-10 AN Fuel Line
Racing Harness only
Full functional lights
Autometer Engine Coolant Gauge
Switch Panel (Ign., Start, Fans, FP, WP)
Plexiglass Front Windshield
Asking $950 SOLD to Shant
Front Drag Brakes
Aerospace Components
Single rotor, not for street use
Asking $225 SOLD to Shant
KTRE 12-Bolt
33-spline axles, Tom’s KA Axles
Spool
2” shorter then 4th Gen (or perfect for 3rd gen)
No E-brakes
No Reluctors for speed sensors (TCS/ABS, ABS only)
Stock LS1 Rear Brakes
Need Stock 10-bolt
Asking $1100 SOLD to Shant
Wenco Driveshaft
Fully Balanced
3.5” Steel
1350 Yoke
Asking $100 SOLD to Shant
Drag Wheels/Tires
Convo Pros 15x4 Ft, 15x8 Rr
ET Front Runners
Et Drag 29.5x9x15
Asking $600 SOLD to Shant
BMR Tubular Front K-Member
4th Gen LS1
Mild Steel
Need your stock K-Member
Asking $300 SOLD to Shant
Mezerie EWP
Race version for LSx Engines
Asking $200 SOLD to Mike
HAL QA1 Shocks
Need to be rebuilt
For 4th Gen F-Body
w/Eibach LT1 Pro Kit Springs
Asking $75 SOLD to Tim
BMR Adjustable LCAs
Rod End design
Mild Steel
Asking $100 SOLD to Tim
BMR Adjustable Panhard Bar
Rod End design
Mild Steel
Custom Gen3 Cam
240’ Duration @ .050” Lift
.603” Lift
113 LSA
110 ICL
Asking $200 SOLD to Tim
Race Ported 241 Heads
Flow around 300 cfm @ .600” Lift
Made 500 rwhp on this setup with a 240 cam
2.02”/1.60” Valves
Asking $800 SOLD to Tim
Intake System[/B]
Accel 4150 4-bbl Throttle Body
GMPP Single Plane Intake (ported)
Ford Green Top Injectors (46#/hr on GM)
Speed Inc Fuel Rails
Autometer Fuel Pressure regulator
Autometer Fuel Pressure Gauge
Asking $950 SOLD to Tim
70,000 Miles
In good shape
Asking $400
B&M TH400
4400 8” Stall
Transbrake
B&M Deep Pan
CSR Trans Shield
BMR TH400 X-Member
ES Trans Mount
BMR Subframes
Fully gutted
Sumped metal tank
-10 AN Fuel Line
Racing Harness only
Front Drag Brakes
KTRE 12-Bolt
Spool
No E-brakes
Need Stock 10-bolt
Wenco Driveshaft
Fully Balanced
3.5” Steel
1350 Yoke
Drag Wheels/Tires
ET Front Runners
Et Drag 29.5x9x15
4th Gen LS1
Mild Steel
Mezerie EWP
HAL QA1 Shocks
Need to be rebuilt
For 4th Gen F-Body
BMR Adjustable LCAs
Rod End design
Mild Steel
Rod End design
Mild Steel
Custom Gen3 Cam
.603” Lift
113 LSA
110 ICL
2.02”/1.60” Valves
Intake System[/B]
