Turbos, 4L80E, Fuel Pumps, Intake, 5.3 motor, Wheels...
Maken some changes and cleaning out the garage.
FI-88X Race Turbo 1.4AR This is new and has never been mounted. We actually bought two and only ran one of the cars in this race series. It comes with a -4 inlet and a -10 drain and a 3.5"-4" silicone coupler.
$1700
Turbonetics 101mm Turbo 1.0AR This has a polished comp housing and there is no endplay. The comp wheel blades closest to the housing are rolled over from rubbing on the housing. This was my fault and left the housing T-bolt loose. I ran it this way for awhile and went 7.97 with it.
$750
JGS 60mm Wastgate This is used and comes with 2 springs.
$250SOLD
Magnafuel MP-4303 Pro Tuner 750 Inline fuel pump. This is like new and only used at one race. Comes with -10 inlet and outlet fittings.
$425SOLD
Magnafuel MP-4701 Swivel head Pro Star 625 This has been used for a couple years but works great. Comes with -10 inlet and outlet fittings.
$425
Comp/ T&D Rocker Arms 1.7 ratio These have very little run time.
$500
Pushrods 5/16 x .083 7.00 long with .040 restrictors. These were used with the above rockers.
$75... $50 if you buy the rocker arms.
LS6 Intake and TB The intake has been smoothed and painted. It could use a recoat. The MAP sensor hole has a fitting and a rubber hose. The TB is stock and home ported and comes with TPS & IAC sensors.
$350SOLD
LS2 Waterpump Think it came off a crate motor. It still has the caps on the heater ports. I bought it awhile back as a spare.
$75
Rossler 210/4L80E and Midwest Racing Converter This is the baddest of the bad 4L80E's built. This is the one I went 7's with. It has everything done to it that Rossler can do plus a 210 gear set. The converter is a custom piece that uses our racing converter with a lockup clutch. Both have just been gone thru and are like new.
$5,000
5.3 Longblock This came out of a 2004 truck with around 14,000 miles. Heads have never been off.
$550SOLD
98-00 WS6 Wheels These are in very good condition. Only a little rub on a couple of them. There are two Goodyear Eagle F1 tires 275/40Z R17 mounted. These have very few miles on them.
$650
All items are OBO and do not include shipping.
$1700
$750
$250SOLD
$425SOLD
$425
$500
$350SOLD
$75
$5,000
$550SOLD
$650
