F/s: LS1 6 Spd Swap.. Lower Price!
Old Sep 26, 2009 | 04:16 PM
danhr's Avatar
Default F/s: LS1 6 Spd Swap.. Lower Price!
Almost everything you need to swap in a 6 speed.
Included is:
GM Bell housing
T-56 Transmission
Crossmember
Stock Shifter
All the hydraulic lines
Clutch resevoir
Master cylinder
Pedals
Upper Shift boot (the one that attatches to the console). It is Ebony and has one crack in the plastic retaining ring.
All you need is a clutch to fit your application, a slave cylinder, and the upper console and you're set!
Transmission originally came out of a 2000 Camaro SS. I then put it in my 97 Camaro when I did my LS1 swap. I had it for a year and now I no longer need it. Everything has a total of 105K miles on it. Transmission generally worked fine (very seldomly did it grind 5th when it was cold outside).
$1250
Will do trades/trades+cash for the following parts:
Victor Jr for L92 heads
60# injectors (must be new)
4l80e (can be stock)
Kooks 2" primary headers
Yella Terra L92 rockers
6 Point Chromemoly roll bar
Old Oct 5, 2009 | 04:47 PM
SS101's Avatar
looking for pedals, crossmember and bellhousing. willing to seperate?
Old Oct 16, 2009 | 07:05 PM
danhr's Avatar
all is sold
Old Oct 16, 2009 | 10:02 PM
blackls1ta00's Avatar
hey man i have a 6 point cb bar with a swingout door on drv side it was used once very nice i was gonna use it but never got around to it pm me an offer its still in the bubble wrap.
