SLP Double Roller Billet Timing Chain Set
NIB Billet Double Roller Set. $75 plus shipping.
SLP's Double Roller Timing Chain Set is designed for 1997-02 LS1 type engines. The new timing chain is the perfect addition to SLP's camshafts and other LS1 engine offerings. The set contains an adjustable, 9 keyway crankshaft sprocket, camshaft sprocket, double row chain, 2 oil pump spacer plates, and hardware. This new timing chain set will allow for timing adjustment advance or retard of 8 degrees. The double chain provides better strength, accuracy and durability. The sprockets are nitrated for even higher strength and longevity. All necessary parts, hardware, and detailed instructions are included.
http://www.lmperformance.com/1699/1.html
