tons of lt1 and ls1 parts for sale
LS1 STUFF
241 casting ls1 heads 75 each set
ls1 fuel rails 40
injectors 34 lb/hr and 60 psi (flow tested with sheet) 250
z06 cam 150
stock ls1 rockers 60
stock maf 60
flexplate 50
2000 black leather door panels perfect...250
passenger ttop 75
stock delco amp...40
stock monsoon radio....75
REARENDS/SUSPENSION
boxed bmr LCA with poly/poly bushngs 75 bux
lt1 steering rack 70 no leaks CLEAN!
ive got 4 sets of lt1 backing plates...
3 channel 40 bux each set
4 channel 55 bux each set
lt1 front brakes with spindles rotors hubs and calipers 75 bux
3.73 rear makes some whining 300
stock front springs from lt1 car 20
rear shocks 20 a pair
LT1 Parts
94 lt1 timing cover...25
95 + timing cover...30
cc306 6k miles.....210 shipped
egr valves 10
lt1 shortblock needs rebuild...150
lt1 oil pan...40
lt1 aluminum heads...200
lt1 intake manifold...65
lt1 injectors...35
lt1 6 speed flywheel...50
complete lt1 motor spun bearing needs rebuild 425
also have many interrior pieces from parting out a 1999 and 2000 z28
full power doors
camaro hatches
rear bumper
couple dashes with blown airbags
brake lines
fuel lines
gas tanks
k members
upper and lower control arms
struts
shocks
spindles
brakes
steering columns
interrior pieces
complete tan interrior/seats/plastics ect
swaybars phb's lca's
359 ci LT1 this shortblock is from Jim Moran aka "INTMD8" His car was well known for the fact that it was a very clean streetable(A/C, T56, full interior) turbo car for the power it was making. To give you an idea, with this shortblock he dynoed 890rwhp/855rwtq, ran a best of 9.68@146, and did 199mph in the standing mile.
Specs:
359ci LT1. 3.5in stroke forged Eagle crank, 6.0in Eage H-beam rods, 4.040 bore CP reverse dome pistons -23cc., Hellfire rings, Clevite H bearings, Internally balanced. Block has 3 center mains splayed 4 bolt. It was freshly rebuilt when I purchased it, including an align hone, new bearings/rings, and the crankshaft was turned .010 under.
asking $1999
1998 chev Blazer 4x4 150k miles red exterrior grey leather fully loaded heated seats...needs a few small things such as door switch(keeps inside lights on) and one speaker doesnt work
$1999
wtb/trade
ls1 6 speed /twin disk clutch
hardened pushrods ls1nstock leingth
powerglide/converter/shifter
50mm wastegate
t4 76mm or bigger turbo
eboost 2
ls1 fuel rails 40
z06 cam 150
stock maf 60
flexplate 50
passenger ttop 75
REARENDS/SUSPENSION
LT1 Parts
egr valves 10
lt1 oil pan...40
lt1 injectors...35
full power doors
camaro hatches
rear bumper
brake lines
fuel lines
gas tanks
k members
struts
shocks
spindles
brakes
steering columns
interrior pieces
Specs:
asking $1999
$1999
wtb/trade
50mm wastegate
eboost 2
