K1 4 Inch Crank, 2 Sets of Pistons, Lunati Rods, AFR Heads, 6L Block, Heads, Interior
OWN3D BY MY PROF!
I've been selling a lot of my mass of items on here over the past months or so and have put together another load of parts for sale. I am consolidating parts and attempting to simplify my Formula build to get it on the road some time soon. I am also in the process of cleaning out my garage for a partial remodel and am in need of space. The less items in there the less I am going to have to move out of the garage once I start removing the wall, painting, and coating the floors. With that said I am open for trades. In building two cars I am in need of quite a few parts. I am semi negotiable on parts. Some things I want to get rid of and others not so much. Shoot me an offer and we can probably work something out.
Please do not send me an offer of $20 shipped on something I am selling for $20 and is going to cost me $25 to ship to you. It will effectively be a waste of both of our time. I live in Jacksonville Beach, Florida zip code 32250. It is listed in my user profile, but to put it in bold this time so hopefully people will read this and not send me a PM simply to ask me where I live.
All of the interior parts came out of my 1993 Camaro Z28. The LT1 engine parts either came out of my 93 Z28 with 118k miles or a 96 Z28 that only had 36k miles. The stock LS1 parts came off of my 98 Formula.
All of the prices I have listed do not include the price of shipping or the 3% paypal likes to rape you on. All parts are sold as is. If you'd like any other pictures or have any questions post up or PM me and I'll get you what ever you'd like. I am also open to trades. I have two cars that I am building and need a ton of parts. Again we can work something out and I'm into helping people.
If the item is not listed under the last post that says, "SOLD ITEMS" it is still available. Please don't ask if something is still for sale when it is clearly listed. You will more than likely get a very sarcastic response or none at all.
AFR 225 Big Bore (1630) Heads = I traded my AFR 205s + Cash for these a little while ago. I am no longer going to use them. The heads are currently at 66cc, have 8019 springs that have just checked at full spring pressure, BRAND NEW Ferrea valves 2.080 intake and 1.600 exhaust, BRAND NEW Titanium retainers and locks, BRAND NEW seals... ALL parts from AFR. Flat in all directions with machinist straight edge. Guide clearance measured and in spec.My Price = $1950 Shipped in the continental US, insured with delivery confirmation
OWN3D BY MY PROF!
Set of 1 inch billet perimeter bolt valve cover spacers. These include the longer bolts, spacers, and gaskets for them. I will not sell these before the heads below sell. My price = $100
OWN3D BY MY PROF!
Hand ported 806 perimeter bolt castings. These heads have had a lot of work done to them. They have a stainless steel O ring in the chambers, been clearanced for 3/8ths pushrods, cut for 2.02 / 1.60 valves, cut for 1.550 diameter valve springs, have guide plates, and been hand ported. I do not know the size of the chambers, runners, or flow numbers. My Price = $350
Stock LS1 rockers, stands, and bolts. My Price = $40
OWN3D BY MY PROF!
From here down is the stuff I don't care too much about. If you want to pick it up I will give you a better price on it than making me ship it. If this stuff doesn't sell soon it is going in the trash or the dumpster down the street.
LT1 Engine Parts... The 93 parts have 118k miles on them and the 96 have 36k.
93 PARTS
Bose front speaker holders = $10
Driver's Side Airbag = $25
Passenger side airbag = $30
Windshield washer fluid reservoir = $10
Emergency Brake Handle and spring = $10
Gauge Bezel. My price = $15
Bottom Dash Piece. My price = $15
Glove Compartment. My price = $15
97 Firehawk automatic center console piece with no ash tray lid. My price = $15
93 PARTS
OWN3D BY MY PROF!
I've managed to sell a lot of things in the past few months. Here's a list:
SOLD ITEMS
- Front Pioneer Speakers. I have no idea what these are, but you can do some research if you'd like. = SOLD
- 93 BNIB Tensioner = SOLD
- Stock 93 intake tubing with IAT sensor = SOLD
- Completely stock 1993 set of cylinder heads. These are complete, but have been taken apart and cleaned. They include the rockers. = SOLD
- Complete set of 1996 cylinder heads assembled = SOLD
- 1996 Vented Opti with 36k miles = SOLD
- 2x one wire O2 sensors. One is BNIB and the other one is newish / barely used = SOLD
- 93 IAC motor = SOLD
- 93 PCM and engine harness for an A4 car = SOLD
- 93 LT1 short block, cam, timing set, oil pump, front cover with 118k miles = SOLD
- Plastic Parts = SOLD Two shrouds, Triangular pieces = SOLD
- Steering Shaft Cover = GONE
- Two chrome perimeter bolt SBC valve covers = GONE
- Mr. Gasket 1932 adapter / spacer. Quadrajet -> 4150 = GONE
- Torque Arm Mount with bolts = SOLD
- Holset HT3B Turbo that I sand blasted clean and reassembled. I know these are popular with the diesel guys out there. = SOLD
- Set of All Pro "Hurricane" Heads. These are bare castings. They need to have guides installed and the seats cut. My Price = SOLD
- Eagle 4 inch crank. I bought this locally from a member on here GTFormula on 07-14-2007 as a 408 setup. I dropped it off at my friend's shop, sprayed it with WD40, rebagged it, and it has been sitting in the same bag ever since. I recently bought a LS7 crank so I could use the dry sump setup off of it.
My Price = SOLD
- Set of eight = 5-16ths Del West 2.152 diameter intake valves, 5.715 length SOLD
- Set of eight = 5-16ths Del West 1.602 diameter exhaust valves, 5.595 length. These are coated. SOLD
- 93 BRAND NEW 0 mile Remand water pump painted gloss black with thermostat housing = SOLD
- BNIB Plug wire set = SOLD
- Loudmouth 1 / LM1: It has one small two inch cut in one pipe where I couldn't get the clamp off. All you'll have to do is slide the down that extra two inches and you are golden. = SOLD
- Stock LS1 Fuel Rails = SOLD
- Stock 98 Fuel Injectors = SOLD
- Stock LS1 intake with EGR blocked off = SOLD
- 96 LT1 short block, cam, timing set, oil pump, front cover, oil pan, windage tray, oil pump with 36k miles - SOLD
- 94+ Intake manifold painted red with MAP sensor and polished fuel rails = SOLD
- lifter spider = SOLD
- BNIB unvented Opti. Includes 4 caps, 2 rotors, 2 middle pieces, and one rear part = SOLD
- 96 lifters with 36k miles = SOLD
- 93 fuel injectors = SOLD
- 93 lifters with 118k miles = SOLD
- 2x Brand new radiator hoses = SOLD
- 2x BNIB Fuel filters = SOLD
- 93 LT1 Starter = SOLD
- I have two of these. They are 2007 GSXR 750 throttle bodies. Each set comes with 8 injectors, the fuel rail setup, and all electronics. = SOLD
- 93 Fuel Rails = SOLD
- 1996 Coil = SOLD
- Coan 8 inch 5200 stall for a LS1 + TH350 / TH400. "[/I] SOLD
- Garrett GT42 SOLD FINALLY
- 2x stock crank pulleys. One 93 and one 96. Both have been sand blasted clean = SOLD
- Set of eight = 5-16ths Manley 1.615 diameter, 5.715 length SOLD
- 96 water pump and thermostat housing 36k miles = SOLD
- Hooker Shorty Headers (Part Number 2060) SOLD
- 2x sets of valve covers with bolts = Both SOLD
- Heater core = SOLD
- 93 used Tensioner = SOLD
- 93 LT1 fuel Injectors = SOLD
- Newer style Comp Cams 918 valve springs with titanium retainers and locks. SOLD
- Two Hooker 3 inch inlet and outlet bullet mufflers. SOLD
- PTC 10 inch 3800 stall with TH splines. SOLD
- 93 Coil, ICM, with plug wire = SOLD
- LS7 cam from a 2008 zo6 427. SOLD
- Comp Cams (LS1) 224/228 .533/.538 113+4 cam . SOLD
- 6 Nitrous Express SX2 Nozzle. SOLD
- 93 Accessory Bracket painted gloss black = SOLD
- 97 4L60E, converter, dust shield, cross member, and shifter = SOLD
- BNIB PCV valve = SOLD
- BNIB Thermostat = SOLD
- Water pump splined drive = SOLD
- Wiseco K394F3, 408 pistons, 4.030 bore, 4 inch stroke, 1.115 CH, -8cc dish, 2618 material. These are brand new in the box. SOLD
- 93 4l60 and converter with 118k miles = SOLD
- 93 Alternator with gloss black painted pulley / fan SOLD
- 98 LS1 fuel rails. SOLD
- 98 LS1 injectors. SOLD
- Chrome Moly 10 point roll cage. SOLD
- 96 Intake manifold, EGR valve, plastic lines, and MAP sensor = SOLD
- 95 Camaro passenger side tail light. SOLD
- K1 Technologies 6.125 rods for a .927 pin with ARP 2000 rod bolts. SOLD
- Complete set of seat belts out of my 93 = SOLD
- 93 LT1 AC compressor. SOLD
- Stock Horns off of a 2000 V6 Camaro. SOLD
- Katech CNC Ported 806 heads and 2.04 intake valves. = SOLD
- 98 clutch and flywheel. SOLD
- 98 LS1 intake manifold. SOLD
- 98 LS1 throttle body. SOLD
- K1 Technologies 4 inch Forged Crankshaft with 24X reluctor SOLD
- Diamond 408, 4.03 Bore, 4 Inch Stroke, -1.8cc Pistons, Rings, Spirolox, and Pins = SOLD
- Lunati Pro Mod 6.125 / .927 Pin Rods = SOLD
- Wiseco K396X3 -32cc dish pistons. SOLD
- 6.0 L iron block = SOLD
- 93 LT1 Dipstick = SOLD
- 2000 Silver Berger Panel. SOLD
As you can see this is a lot of stuff. If you don’t see something on here I may actually have it available. Shoot me a PM, if I have it and want to get rid of it we can work something out.
SOLD ITEMS
My Price = SOLD
- 1996 Coil = SOLD
OWN3D BY MY PROF!
All stupid PMs or PMs from people who do not read the thread will be ignored.
I'm not trying to be an ***, but this comes straight from the first post in bold, italic, underlined, and sized up text. This is just a copy and paste.
What do you need to know? There's only a couple issues when selecting heads that are usually will they fit or what is my compression going to be. It honestly isn't that difficult. If you need help PM me with questions and I'll answer them to the best of my ability.
OWN3D BY MY PROF!
98 LS1 Intake manifold, throttle body, clutch, and flywheel have been sold. The thread has been updated to reflect this. Everything that is listed in the thread with prices is still available.
