WTB: Intake, Harness, Oil Pan, Valve Covers, T-56....
I need quite a few parts to finish up my LS1 RX-7 Build...As of right now All I have is a motor minus intake, oil pan, timing, valve covers, etc...I just have motor with heads and MS3 cam.
I need....
Everything else...
Let me know what you've got!
-Tyler
I need....
Everything else...
- Intake (LS6...?)
- Throttle Body and linkage
- F-Body Oil Pan
- Timing chain cover (probably new chain, as well)
- T-56
- LS7 Clutch (preferred)/Flywheel
- Shifter
- Valve Covers
- Injectors
- Fuel Rails
- Water Pump
- Oil Pump (LS6 ported!)
- Wiring Harness from a 6 speed car
- Driveshaft from a C4 'Vette...?
-Tyler
I need....
Everything else...
-Tyler
I need....
Everything else...
- Intake (LS6...?)
- F-Body Oil Pan
- T-56
- Shifter
- Valve Covers
- Injectors
- Fuel Rails
- Water Pump
-Tyler
Thanks!
I have a LS6 intake with gaskets and bolts for $315, timing chain cover $25, JP double roller timing set with under 3k miles in perfect condition $60, 37lb flowmatched injectors(with flow sheet)$190, and ported LS6 oil pump with 3k miles $65. PM me with any questions, prices listed inlcude shipping. You can paypal me at K12secformula@aol.com.
Thanks!
I have a timing chain cover powdercoated black $40
2001 PCM that I can flash a 6 speed tune for you $125
Also have a harness. It is for an auto but will work with no issues, it was working on a car that was converted to a six speed. $200
PM me if interested
PM me if interested
