Procharger kit
I have a D1sc with a fmic setup and 8rib upgrade, 50lbs injectors, Autometer electric fuel pressure gauge & boost gauge, a March underdrive crank pulley that a friend and I drilled and tapped to use with a spacer. The crank pulley is 7.65" and the blower pulley is a 3.9" You would need a fan setup as I just ran with one stock one cut out. And to also plug/use two holes in one of the tubes before the t/b that were used for the meth jets I was running.
This setup has around 7000 miles on it. $4,000 picked up.
