Lots LSX engine parts check out
8 SEC SLOPPY SHOT!!!
I have all these parts that were takin out of my old 408, The block was bad so i just have these parts left over.If you need better picture of a item your interested in leave me a pm with you e mail address.
Thanks,Mike
Lunati 4 in crank .010 onder on mains and rods 550.00
Lunati pro billet rods with je pistons rods 6.125 and pistions are .030. 600.00 SOLD
Ati damper single groove with arp bolt 200.00
Aluminum valve covers 100.00
Arp L19 head studs one washer missing 250.00
Arp main studs 125.00 SOLD
Bogart wheels drilled for screws 10 7.5 bs no spacer on wheels 350.00
Rollmaster double roller timingchains i have two. 75.00 complete in box and one set out of box with loose parts 50.00
4150 accel throttle body with iac no tps sensor.200.00 SOLD
moroso oil pan has oil return needs cap off and miner wheele dent 350.00 SOLD
comes with windage and oil pickup
Racetronic 550cc injectors i think there 55lbs like new 250.00
GZ vacuum pump.125.00 SOLD
Thanks,Mike
When i bought the crank it was a new take out of a customers engine that the guy bailed on and was not finished.I think it was a hole were they possibly had heavy metal removed and filled.Only thing that ever happened with the crank when i ran it was a thrust bearing let go.I ran a full season on it as it sits.We went 8.80 back then with the crank.
