Notices
LS1 timing cover gasket and Crank pulley install tool
Old Nov 2, 2009 | 11:07 PM
sscamaro1384's Avatar
Default LS1 timing cover gasket and Crank pulley install tool
Im looking for these tools
anyone got them used. Im doing a cam swap soon and need the crank installer tool and valve spring tool
Also looking for a new LS1 timing cover gasket
Let me know if u got it
Old Nov 3, 2009 | 01:47 PM
am_muscl's Avatar
the valve spring tool is only like $30 shipped and you can go to autozone and rent the install tool and when you're done you get the money back
Old Nov 3, 2009 | 03:13 PM
Magnet's Avatar
whats the installer called at autozone?
Old Nov 4, 2009 | 03:22 PM
am_muscl's Avatar
i believe it's a 3-claw puller? but that's to remove the crank, to install it you can just make your own tool, go to ACE Hardware buy a hardened threaded rod with some hardened washers and a nut, that's what I did and the crank hub went on like butter.
Old Nov 8, 2009 | 09:22 PM
what are the dimensions of the threaded rod?
Old Nov 10, 2009 | 04:47 PM
am_muscl's Avatar
i believe it is a 7/16"x20? it's a fine thread
Old Nov 16, 2009 | 06:56 PM
got the spring compressor but need the timing gasket and install tool
Old Nov 16, 2009 | 06:59 PM
Project382's Avatar
I've got the timing cover gasket and new cam plate (has silicone molded into plate to seal cam). PM me if interested.
Old Nov 16, 2009 | 07:10 PM
pm sent
Old Nov 24, 2009 | 08:31 PM
Got the timing cover.Thanks project 382. Thanks LS1tech
Old Dec 2, 2009 | 09:39 AM
gtpvette's Avatar
https://ls1tech.com/forums/lsx-parts...tall-tool.html
