P&P 243 Heads, LS2 Pistons Rods, ARP, PRC, Etc. Tons of Braking-Suspension Parts Pic
The Prices are NOT FIRM so if something seems too high in price, Let me know and we'll work it out !!!
Also look at My Sig for the links to the rest of my Sales !!!
Prices are plus shipping and 3% Paypal.
Ported and Polished 243 Heads by House of Power - $895 !!! (8 Hrs of porting = $800)
Patriot Dual Springs with retainers, Seats and Super 7 Locks Like NEW, Only Less than 4K miles - $229 !!! - Good for up to .650 Lift !!!
Set of 8 LS2/LQ9 Pistons and Rods (Full Floating Pins) with 20K miles - $395 !!!
LS2/LQ9 Pistons (Only 6 Left) - $39 Each !!!
ARP 12 Point Studs '03 and under LS1 Like NEW (ARP-234-4316) - $239 !!!
http://www.jegs.com/i/ARP/070/234-4316/10002/-1
ARP Bolts '04+ LS1 Like NEW (ARP-134-3610) - for Only $99 !!! (Just Bolted once for 4K Miles)
http://www.jegs.com/i/ARP/070/134-3610/10002/-1?CT=999
New LS2 Timing Chain - SOLD !!!
GM LS1 5.7 Head Gaskets Stock NEW - SOLD !!!
26Lbs Injectors - $10 each !!! I only have 7 or $50 for all !!
LS1 Windage Tray - $29 !!!
LS1 Coils - $20 each !!!
F-Body LS1 Motor Mounts - SOLD !!!
Poly Bump Stops NEW (Bought from a member here but never install them) - $50 !!!
Brand New Mr. Gasket Exhaust Gaskets Ultra Seal - $23 Shipped !!! I paid almost $35 for them...
A/C Compressor with lines and Bracket - $145
A/C Line with sensor - $39 !!!
A/C Evaporator - $25
A/C Condenser - $50 !!!
Accessories and A/C Belts Low Miles $34
Stock SS Tailpipes / Tips - $35 !!!
Stock Y-Pipe only 30K miles $39
LS1 Intake with Plug - $65
LS1/LS6 Intake Gasket Kit Brand New - $55 !!!
EGR Pump and Lines - $65
AIR System Pump and Hoses - Make an offer !!!
LS1 Roller Rockers $9 each
Oil Pan Tray $20
LS1 Fans with Low Miles - $99
Radiator Hoses $18 Each
Hose to Booster $12
Throttle Position Sensor $75
Oil Pan Tray $20
Hose to Booster $12
97-08 Corvette and 05-06 GTO Front Hawk Pads NEW (HB247F.575) - $89 set
http://www.summitracing.com/parts/HWK-HB247F-575/
82-97 Camaro/Firebird and 88-96 Corvette Rear Hawk Pads NEW (HB112F.540) - $49 set
http://www.jegs.com/i/Hawk/486/HB112F.540/10002/-1
97-08 Vette Hawk Competition Pads used for 1 Day but look NEW - SOLD !!!
http://www.summitracing.com/parts/HWK-HB247N-575/
Hawk Performance's HP Plus disk brake pads are designed for sports cars, coupes and sedans for sport driving in autocross, Solo II and many “track day” applications. Additionally, the Hawk Performance HP Plus Ferro-Carbon compound can take the heat at the track and get you home safely without having to change your brake pads in and out. This compound was designed for the serious street and autocross enthusiast.
Key Features and Benefits of Hawk HP Plus Brake Pads:
-Extremely high friction output
-Suitable for autocross events
-Race worthy for club racing
-Elevated temperature resistance
Stock Font Pads (tons of life left) $45
Set of GM Camaro LS1 Rotors "READY TO USE" Front or Rear $69 each set "FREE SHIPPING"
Brake Hoses $20
Brake Master Cylinder $45
Brake Lines from Master to the Block - $20 each
ABS Brake Block - $60
Cruise Control Module - $95
Front Pass Spindle $65
10 Housing with Relocation Brackets Weld in $80
10 Bolt C-Claps Axel holders $15
Emergency Brake Cable $25
LT1 Front Calipers RED with CAMARO on them $75
LT1 Performance Pads $45
Front Drilled LT1 Rotors $65
LT1 Spindles $45 Each
Brake Hoses $20
[QUOTE=mighty-z28;12458285]They are Used (Just Bolted once for 4K Miles) but Like NEW !!! I'll even include a New assembly lube
PM sent.
PM sent.
