6.0 forged rotating assembly
i have a set of carrillo rods new bearings arp 2000 rod bolts stock 6.0 crank and wiesco turbo pistons 4.005 -25cc dish 8.1-8.6 CR depending on what heads you run. buy your self a 6.0 block and run with it 1200 obo i also have a o ringed 6.0 block i will include for 400 or 500 with main studs this block needs 1 of 2 things done it needs to be pinned and re honed or needs new main caps and re honed o ringing a block cost 400 alone pics will be uploaded tonight
this is for stock bore 6.0
What length of rod are those pistons for? I'm not familiar with Kaltech rods.
So the block just needs honed to fit the pistons?
Chris
Chris
no the block has been honed the pistons fit perfect but 2 of the main caps are a little loose so the 2 will need to be replaced and re honed or keep the main caps pin them and re hone thoes are the 2 options
