LS1 scanmaster, Bilstein BTS lowering springs, O2 extensions
Old Nov 18, 2009 | 07:33 PM
Matt00SS's Avatar
Default LS1 scanmaster, Bilstein BTS lowering springs, O2 extensions
Everything is gone; thanks!
LS1 scanmaster -- $125 shipped -- SOLD
Bilstein BTS springs, ls1 f-body (I believe they lowered the front 1.25" and rear 1.75") -- SOLD
LS1 scanmaster, Bilstein BTS lowering springs, O2 extensions-bilstein_springs.jpg
24" O2 extensions (Qty 2) -- SOLD
Old Nov 19, 2009 | 09:29 AM
Matt00SS's Avatar
Displays the following and allows you to view and clear DTCs
MAF - Mass AirFlow (lb/Min)
SP - Spark Advance (Degrees)
Pu1 - Injector Pulsewidth Bank 1 (Milliseconds)
Pu2 - Injector Pulsewidth Bank 2 (Milliseconds)
Dtc - Diagnostic Trouble Code (Powertrain diagnostic code)
MPH - Miles Per Hour (Vehicle speed)
Lt1 - Long Term Fuel Trim Bank 1 (+/- Percent
Lt2 - Long Term Fuel Trim Bank 2 (+/- Percent)
CEL - Fuel Trim Cell (Cell number)
St1 - Short Term Fuel Trim Bank 1 (+/- Percent)
St2 - Short Term Fuel Trim Bank 2 (+/- Percent)
O1 - Oxygen sensor millivolts Bank 1 (Millivolts)
O2 - Oxygen sensor millivolts Bank 2 (Millivolts)
AtS - Air Temperature Sensor (Degrees F)
CLt - Coolant Temperature Sensor (Degrees F)
TPS- Throttle Position Sensor volts (Volts)
TPP- Throttle Position Percentage (Percent)
R- RPM
IAC- Idle Air Control steps (Steps)
BAt- Battery voltage (Volts)
Egr- EGR position (Percent)
MAP- Manifold Absolute Pressure (KPA)
Old Nov 19, 2009 | 10:18 AM
rtr2001ss's Avatar
Free bump for you, I have one of these and the thing work in just about any OBDII car, GM wise. Works in my 06 Silverado, worked in the 03 Astro Work van I used to drive, also worked in my brothers wifes 99 Cavalier. It doesn't work on the new CAN OBDII cars, ie newer Impalas and such, as well as the Cobalts.
Old Nov 19, 2009 | 11:32 PM
Matt00SS's Avatar
thanks, It's a great tuning and diag tool.
Old Nov 20, 2009 | 09:57 PM
Matt00SS's Avatar
anyone?
Old Nov 21, 2009 | 11:44 PM
Matt00SS's Avatar
to the top
Old Nov 22, 2009 | 07:04 PM
Matt00SS's Avatar
still available
Old Nov 23, 2009 | 09:13 PM
Matt00SS's Avatar
to the top
Old Nov 24, 2009 | 09:14 PM
Matt00SS's Avatar
daily bump
Old Nov 25, 2009 | 09:15 AM
fast's Avatar
take 100 for it?
Old Nov 25, 2009 | 12:13 PM
Matt00SS's Avatar
pm sent
Old Nov 25, 2009 | 03:50 PM
JTelesone's Avatar
Ill give you 100 shipped for it. it will diag my ses light correct?
Old Nov 25, 2009 | 04:05 PM
rtr2001ss's Avatar
It'll tell you the code, but then you'll have to look up that code. It can clear codes too, all you have to do is have it plugged in, then turn key to on, while the unit is powering up you hold the left button till "CLR DTC" appears, then you let go of the left and push the right button.
Old Nov 25, 2009 | 09:26 PM
Matt00SS's Avatar
PM sent
Old Nov 25, 2009 | 10:06 PM
Gordo78's Avatar
Do you have paypal? Take 20 shipped for the o2 extensions?
Old Nov 25, 2009 | 10:36 PM
Matt00SS's Avatar
pm sent
Old Nov 26, 2009 | 08:34 PM
Matt00SS's Avatar
o2 extensions are sold.
Old Nov 27, 2009 | 10:50 AM
Matt00SS's Avatar
springs are sold
