LT1/LT4 parts for sale
Im parting out the LT1 engine in my car. Everything that is LT related in the car goes. Getting ready for the LSX project. All parts have roughly 1500 miles on them unless otherwise noted.
Heres what I have.
AFR 210 heads ported by Elliot portworks w/flowsheet. Has 217 runners complete. 7/16 studs and PR guides. 64cc minor marks on #7 chamber sent to Machine shop for repair and pressure checked. $1800
Comp Cams Solid Roller cam 242/248 .610/.630 lift on 1.6ra.
will sale with Solid roller lifters $350
Dynaspark Opti 93-94 Gen1 vented. same mileage as cam. $350
SVO 42Lb injectors Green Top ( 8 ) SOLD
LT4 Intake ported to max. 2.5" runners. ready for mono-blade.
Tig welded on runners for added runner height. w/ egr block off plates. etc... Matched to LT4 Intake Gasket and portwork by Elliot Portworks $300
383 Rotating assembly balanced. Scat crank,scat 5.7 rods,Ross 400 pistons
crank has never been turned but will require .010 barely spun
#5 rod bearing. Pending
Stud Girdle w/ ARP main studs. Windage Tray/ and factory Oil pan clearanced for the girdle. Girdle is also clearanced for 3.75 stroke (383)
Oil pan is tapped for oil drain turbo/SC/etc... 8an male $250 all of it
Polished Aluminum Valve covers center bolts.Fair condition. SOLD
T-56 3rd and 4th gear are proshifted by Liberty Gear. Steel upgraded forks and new slider gears/syncros. Built by TDP.SOLD
Pro 5.0 shifter mustang stick with Aluminum pollished ball SOLD
94 LT1 engine harness and PCM with LT4 knock module $200
harness has a few splices in it.
Mccord Dual 3" electric cutouts. All wiring and switch SOLD
Pacesetter longtubes 1-3/4" ceramic coated. No EGR SOLD
will ship Y-pipe with 3" cutouts does not include mccord SOLD
LT1 Scan Master. $120
BBK 52mm throttlebody Sold
Also have 2006 6.0L parts in LSX section https://ls1tech.com/forums/lsx-parts...tuff-sale.html
PM or You can also email me brentt94z@gmail.com
Shipping will be calculated extra.
Brentt
Heres what I have.
Brentt
Gotta sale these heads. Someone make a reasonable offer!!
7/16 ARP studs/AFR guide plates. 2.08in/1.6ex valves. (info at the top of thread)
[IMG]
[/IMG]
Also some Comp Pro Magnum 1.6 7/16 nsa rockers. These just recently went on the car. Only have a few runs on the dyno and couple passes on the track.
$225 firm.
[IMG]
[/IMG]
[IMG]
[/IMG]
Email brentt94z@gmail.com or PM me!
[IMG]
[/IMG]Also some Comp Pro Magnum 1.6 7/16 nsa rockers. These just recently went on the car. Only have a few runs on the dyno and couple passes on the track.
$225 firm.
[IMG]
[/IMG][IMG]
[/IMG]Email brentt94z@gmail.com or PM me!
