Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
9 sec fbody part out, lots of stuff, ls1/lt1...what do you need?
Old Dec 10, 2009 | 12:14 PM
LittleRedZ's Avatar
Default 9 sec fbody part out, lots of stuff, ls1/lt1...what do you need?
First of all mods plese dont delete this thread i'm going to post this also in Non Ls1 parts section as i have alot of stuff that would fit ls1 and non ls1 cars and its way to complicated for me to make 2 threads seperating these parts.
1. I have a DLS 9" rear end for sale, Strange center section Spool, 3.55 gears,moser 35 spline axles no options besides Drain Plug, rear is like new with only few hundred miles on it and about 20 track passes.
SOLD!!!!!!
2. Spoohn fully adjustable Trq arm for long tube headers like new condition.
$300+ shipping
3. Spoohn Lower control arms(poly bushings) adjustable like new.
$150+shipping
4. Spoohn Adjustable Panhard rod(poly bushings) Like new.
$95+shipping
5. Spoohn 1" sway bar like new
SOLD!!!!
6. Qa1 "R" 24 way adjustable Coil overs with wrenches and thrust bearings&struts mounts complete with Rear Strange 10way adjustable shocks
SOLD!!!!!
7.MSD Boost a Pump like new
$195+shipping
8.Lt1 Red Big Block Fiberglass hood has a decent amount of paint chips but overall in good shape
this is the only thing i wouldnt want to ship unless somone arranges shipping
$150
9.Lt1 Meiziere Electric Water pump with housing and new temp sensor with abotu 4k miles
SOLD!!!!
10. Ati SFI aprooved Lt1 flex plate good condition some paint chips
$75+ shipping
9. B&M Pro Ratchet shifter with Cable, only Missing the arm that goes on the trans that cable hooks up too, called b&M they said that part is like $15
$185+shipping
10. Steel driveshaft to mate short tail TH400&9" paid 300+ new, its like new.
SOLD!!!!!
11. Brake upgrade Lt4 ZR1 slotted 13" front rotors with Dual Piston Aluminum PBR caliper with pads and Steel Braided lines comes with Front Knuckles and Hub/bearing for both sides these have about 10k miles on them just sitting around got a little rusty.
$250 for everything + shipping
12.acceletronics 95# low impidience injectors like new.
SOLD!!!!!!
13.Fuel system Lt1(or also could be used for Ls1 car if you modify your fuel rail like i did to this one) This system requires for either a sump your tank or just weld a 10AN bung into your tank. Elimunator Aeromotive fuel pump, Aeromotive filter and Fuel pressure regulaor. Comes out of the Nos Y one line goes straight to Fuel rail, another line clamps before you stock fuel filter with stock return. My car made 725rwhp on this fuel system with no issues.
$550 with the fuel pump or i can seperate the pump for $250+shipping
14.Accel DFI Gen7+ fuel managment system with CD and USB cable with MSD 6A Box Incorporated into the harness my car was blowing out spark without the msd.
$850 Shipped
15.Weld Wheels and tires they are in good shape i would say 7 out of 10,the wheels are not bent 1 rear wheel is scuffed up a little but its not noticable. Package comes with Hoosier Full slicks with plenty of life left 28x9. Front tires are like new, comes with caps and Lugnuts(open end lugnuts on rear)15x3.5/15x10
$500 + shipping
I also have some stock Parts
lt1 starter with 2k miles on it gold unit from napa like new
$75
Lt1 stock radiator in good condition- make an offer
Lt1 stock Power steering pump-make an offer
Lt1 a/c delete pulley/bracket $25+shipping
Lt1 factory tailights in cood condition make an offer
Lt1 factory mirrors black in color power make an offer
Lt1 Cloth(grey) door panels one has a small crack around the door handle area otherwise in good condition make an offer
Rear black interior plasic qtr panel covers in good condition make an offer
LS1 T-tops mint $150+ shipping
Lt1 CLear corners in good conditiong $20 shipped
Brake booster with Master Cylender make an offer
Old Dec 10, 2009 | 12:40 PM
Benny Tocamelo's Avatar
PM'ed ya!
Old Dec 10, 2009 | 12:58 PM
projectcam's Avatar
Bump for a Good seller.
Old Dec 10, 2009 | 01:58 PM
LittleRedZ's Avatar
thanks bud how did everything work out for you?
Sale on 9", coil overs and driveshaft pending
Old Dec 10, 2009 | 03:53 PM
smok'nZ's Avatar
MASS seller approved
will you seperate the draglites?
Old Dec 10, 2009 | 04:01 PM
Pewter53's Avatar
are those screws in the drag lites ?
Old Dec 10, 2009 | 04:26 PM
LittleRedZ's Avatar
no sorry would like to sell as a set
Old Dec 10, 2009 | 04:27 PM
LittleRedZ's Avatar
yes they are screwed in more then 700rwtrq likes to spin the tire on the rim
Old Dec 10, 2009 | 06:42 PM
LittleRedZ's Avatar
QA1s, 9",Driveshaft SOLD!!!!
Old Dec 10, 2009 | 09:04 PM
projectcam's Avatar
Everything has worked out great, buyers can buy with confidence. Andre is a stand up guy.
Old Dec 10, 2009 | 10:37 PM
conde'strans's Avatar
I know you had the sway bar with a "9 but would it work with a 12 bolt? Which sway bar is it for strictly drag racing or for handling?
Old Dec 11, 2009 | 02:33 AM
MacGyver's Avatar
pm sent on torque arm and LCA's
Old Dec 11, 2009 | 03:49 AM
birdmaro's Avatar
lt1 taillights? as in the all red ones?
how much do you want shipped to 60164. pm me whenever ya get in a chance. i'm in no hurry...
Old Dec 11, 2009 | 07:22 AM
LittleRedZ's Avatar
handling its not a full out drag sway bar, it would work with any rear as long as you got an fbody
Old Dec 11, 2009 | 08:55 AM
Blade Macias's Avatar
pm sent
Old Dec 11, 2009 | 01:09 PM
will you take $100 shiped for sway bar
Old Dec 11, 2009 | 06:13 PM
LittleRedZ's Avatar
FUEL INJECTORS AND Waterpump SOld
Old Dec 11, 2009 | 06:16 PM
LittleRedZ's Avatar
Sway bar also Sold!
Old Dec 12, 2009 | 07:17 AM
LittleRedZ's Avatar
sale on wheels and tires pending
Old Dec 12, 2009 | 08:51 PM
LittleRedZ's Avatar
bump this up for tonite lots of things gone already
