LS2 Pistons, Hawk Pads, SLP, 160 Stat, Fans, Gaskets, Etc... NEW LOWERED PRICES !!!
Plus if you get more than one, I'll give you a Package Price !!!!
Also look at My Sig for the links to the rest of my Sales !!!
Prices are plus shipping and 3% Paypal.
SLP **** - $45
Set of 8 LS2/LQ9 Pistons and Rods (Full Floating Pins) with 20K miles - $275 !!!
LS2/LQ9 Pistons Full Floating Pins (Only 7 ) - $29 Each !!!
Set of 8 LS2/LQ9 Rods (Full Floating Pins) - $175 !!!
Hypertech LS1 160 Degree Thermostat - $38 !!!
http://www.c5racer.com/catalog/m36/H...duct_info.html
Poly Bump Stops NEW (Bought from a member here but never install them) - $48 !!!
Brand New Mr. Gasket Exhaust Gaskets Ultra Seal - $18 !!! (I paid almost $35 for them...)
LS1 Fans with Low Miles - $95
28# Lbs Injectors - $65 !!
LS1 Coils - $18 each !!!
97-08 Corvette and 05-06 GTO Front Hawk Pads NEW (HB247F.575) - $85 set
http://www.summitracing.com/parts/HWK-HB247F-575/
SLP **** - $45
O2 Sensor "AC AFS 139" 40" long $44 Each
O2 Sensor "AC AFS 98" 16" long $28 Each
a
O2 Sensor "AC AFS 97" 12" long $24 Each
A/C Compressor with lines and Bracket - $135
A/C Evaporator - $25
A/C Condenser - $48 !!!
Accessories and A/C Belts Low Miles $29
Stock SS Tailpipes / Tips - $34 !!!
Stock Y-Pipe only 30K miles $30
LS1 Intake with Plug - $55
LS1/LS6 GM Intake Gasket Kit Brand New (GM 12533587) - $45 !!!
EGR Pump and Lines - $55
AIR System Pump and Hoses - Make an offer !!!
LS1 Roller Rockers $8 each
Oil Pan Tray $18
Radiator Hoses $10 Each
Hose to Booster $10
Throttle Position Sensor $69
a
Oil Pan Tray $18
Hose to Booster $10
Stock Font Pads (tons of life left) $40
Set of GM Camaro LS1 Rotors "READY TO USE" Front or Rear $65 each set "FREE SHIPPING"
Brake Hoses $18
Brake Master Cylinder $40
Brake Lines from Master to the Block - $15 each
ABS Brake Block - $50
Cruise Control Module - $79
10 Housing with Relocation Brackets Weld in $70
10 Bolt C-Claps Axel holders $12
Emergency Brake Cable $20
LT1 Front Calipers RED with CAMARO on them $65
LT1 Performance Pads $40
Front Drilled LT1 Rotors $60
LT1 Spindles $40 Each
Brake Hoses $18
