Times are tough sale (ramps,radio,fan,springs)
Monsoon head unit for 4th gen T/A $50 (bought it for my WS6 but traded the car off before I could install) Sale pending
Brand new BMR lowering springs part#BMR-SP001R $150 SOLD
Brand new TCI tranny pan for 4L60E $130Sold
Designed with cooling fins to dissipate heat
TCI Aluminum Deep Pans One of the best investments you can make to assure longevity of your automatic transmission is a cast aluminum deep pan. Designed with cooling fins to dissipate heat faster, these pans also provide additional strength and rigidity to the transmission case. No modifications are necessary to the stock dipstick and the pan includes magnetic drain plug, pan gasket and new rail bolts and washers. Holds 2 additional qts.
Brand new/never out of the box race ramps $329 at Summit, yours for $275SOLD
Race Ramp 67 in., 2-piece XT ramps are ideal for low ground clearance vehicles with tires up to 12 in. wide. With an incline of only 10.75 degrees, they raise the car 10 in. and hold up to 3,000 lbs. per set, while weighing only 15 lbs. each, due to being built with Space Shuttle foam technology. Once you have your vehicle secured with these 2-piece XT Race Ramps, you can remove the back "ramp section" and have access from the side of the vehicle, as well as from the front and rear. Like all Race Ramps products, they will not slide across a garage floor, dig into an asphalt driveway, or scratch or otherwise damage a cement or painted floor. They can be used on grass, dirt, or almost any other flat surface, and they will never rust. Race Ramps come complete with straps for easy carrying and storage.
ALL PRICES INCLUDE SHIPPING
Last edited by -1SLOWSS; Dec 29, 2009 at 02:15 PM. Reason: updated list after sale items
No they are not. Got these before the new ones came out. Here is a link to the sponsor sales thread where I got them with all the info
https://ls1tech.com/forums/sponsor-s...ring-sale.html
Springs, ramps, fan/shroud are all SOLD. Still have the T/A head unit and the new tranny pan, and my export tail lights for 4th gen Camaro
https://ls1tech.com/forums/lsx-parts...il-lights.html
No, it is not brand new. I bought it from 98BADAZZTA in March of 2007 and never had the chance to swap out the malfunctioning one in my WS6 before I traded it. I honestly do not know how long he used it, I just know that when I bought it he said it worked great and was not locked
Thanks for your interest
