Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
***2000 SS camaro part out! 98' stuff too!!ADDED STUFF AGAIN****
Old Dec 23, 2009 | 11:04 AM
promod1955's Avatar
Default ***2000 SS camaro part out! 98' stuff too!!ADDED STUFF AGAIN****
Category: Racing Parts
Price: $1
Location (State): VA
Item Condition: Used
LS Engine?: Fits LS Engine
The stock stuff is up top, aftermarket stuff below
Selling a bunch of the stock stuff on the stock internal car. Were using the shell of the car so stuff like the hood and spoiler etc are not for sale. The engine is not for sale. basicly everything else is.
this is all pretty low milage stuff:
***Bring me $350 and you can have all the stock parts listed below***
BODY:
*00' t-tops $220
*00' t top/doorjam passenger side weather stripping $30
*00' windshield wiper linkage and motor $30
*00' stuff behind the front bumper, styrofoam, metal bumper $30
*00' silver hood hinges $30
*00' rear bumper support / crash thing $30
*00' plastic that bolts to outside bottom of bumper $30
*00' under car heat sheilds $20
*00' uncut door bars $30
*00' body control module BCM $50
INTERIOR:
*98' hard top a pillar trim $60
*00' t top headliner $40
*98' hardtop headliner $40
*00' trunk plastics $50
*00' ebony dome light $35
*98' gray dome light $35
*00' b pillar speaker covers $20
*00' kick panels $40
*98' center console door $40
*00' auto shifter $50
*00' hatch fold down divider $30
*00' t top well carpet $30
*00' passenger airbag and module $50
SUSPENSION and BRAKES:
*98' rear brake calipers $80
*00' torque arm $20
*00' panhard rod $20
*00' panhard brace $20
*00' torque arm mount $20
*98' k member and pedestals $60
*00' k-member, lower control arms, engine pedestals, brake lines $80
*00' front sway bar $30
*00' upper control arms and mounts $30
*98' auto steering column with key $30
*00' rear end housing bump stops $50
*00' power brake booster $30
*00' master cylinder $30
ENGINE and TRANSMISSION:
*00' over flow tank/battery mount (has broken tab for front of battery) $20
*00' air pump and EGR stuff $30
*00' 3.23 gear $30
*00' plug wires $20
*98' plug wires $20
*00' exhaust manifolds $50
*00' stock air lid, silencer, new air filter $20
*00' complete ac/heat system inside/outside with switch panel, compressor, bracket to engine, heater hosesetc... $200
Aftermarket parts
***I had this exhaust sold months ago, recieved a deposit and the buyer has vanished and I have not heard from him in months, I'm done playing games so I'm relisting this***
The tubing is all 3" 304 stainless that was bought from the best mandrel bender out there, SPD in California. There is $1100 in just stainless material to build this exhaust. Thats no labor what so ever. Your looking at about a $2200 exhaust system to buy the materials and fabricate everything.
This exhaust system only weighs 10 pounds!! I was using it with qtp headers. This tucks up nicer then any exhaust system out there! Its basicly brand new. Only took this exhaust system to the track twice and made 10 passes with it. The new class im going to be running with the car, we don't have to use an exhaust system so I'm just going to run open headers.
This comes with the 4130 chromoly trans mount, chromoly driveshaft loop, and the stainless exhaust system pictured.
I was asking $1400 months ago when it was "sold". First one with $1100 gets it.
This is no cookie cutter exhaust system. It is x-piped and has a fabricated stainless muffler just past the driveshaft loop. Thanks for looking
SOLD stuff
-wheels
-rear end
-Transmission
-wiring harness
-shifter cable
-power steering pump and bracket
-alt and bracket
-rear springs
-front shocks
-cats
-monsoon head unit
-Steering wheel and airbag
-monsoon speakers
-monsoon amp
-slp asr switch
-front and rear seats
-both sets of front spindles
-all the 98 interior plastic
-seat belts
-one of the hatch dividers
-98 door panels
-plastic t top holders
-98 dash
-factory y-pipe
-powermaster battery
-emergency brake parts
-driveshaft
-ebony sunvisors
-crank pulley
-ABS block
-ASP crank pulley
-cuise control
-ASR motor
-wipers and arms
-hood latch stuff
-Front brakes
-top shock mounts
-Corbeau seat adapters
-chrome hood insert
-carpet
-torque converter
-steering rack
-steering shaft
-tie rod ends
-power steering lines
-power steering cooler
-radiator hoses
-98 sunvisors
-front springs
-rear swaybar
-washer bottle and pump
-fuel tank w/ sender
-inner fenders
-foglights
-rear lca's
-winshield plastic
-slp exhaust
-center console
-msd plug wires
-rear shocks
-98 dash pad
-motor mounts
-radiator
-radiator fans
-lower air lid/radiator support
-transmission crossmember
-fast toys air lid
-corbeau seats
Old Dec 23, 2009 | 12:19 PM
00maro's Avatar
do you have ebony carpet? if you do how clean is it and how much for it?
Old Dec 23, 2009 | 12:49 PM
promod1955's Avatar
I do have a real clean ebony carpet but its cut out for a wolfe 6 point roll bar
Old Dec 23, 2009 | 12:57 PM
Turbo LS1 SS's Avatar
ebony dome light and ebony flip down mirrors/visors?
Old Dec 23, 2009 | 01:25 PM
promod1955's Avatar
using the dome light. $80 for the visors
Old Dec 23, 2009 | 03:28 PM
01redm5's Avatar
Im looking for the small switch bezels for a power window/lock/mirror car. I only need the drivers side, but would take both if you got them. For referance.... http://www.hawksthirdgenparts.com/pr...SWITCHTRIM.jpg
let me know if you got them.
Old Dec 23, 2009 | 06:38 PM
promod1955's Avatar
the only ones i have are on the door panels with the switches im selling complete.
Old Dec 23, 2009 | 07:33 PM
promod1955's Avatar
added some stuff...
Old Dec 23, 2009 | 09:53 PM
lemons12's Avatar
SLP still sell that reverse TSC?
Old Dec 23, 2009 | 09:55 PM
promod1955's Avatar
I have no idea, but man it makes it nice not having to turn it off every single time you start the car.
Old Dec 23, 2009 | 10:04 PM
lemons12's Avatar
PM sent
Old Dec 23, 2009 | 10:18 PM
bill12690's Avatar
that exhaust.....
Old Dec 23, 2009 | 10:24 PM
promod1955's Avatar
it would look sweet on the beautiful blue ss you got!
Old Dec 23, 2009 | 10:32 PM
98chevyz71's Avatar
what kinda stock suspension parts you got? im looking for some stock springs and possibly shocks/struts
Old Dec 23, 2009 | 10:43 PM
promod1955's Avatar
i have the factory rear LCA's, panhard, torque arm, rear shocks, rear sway bar, front sway bar, stock k member, stock front lower control arms, stock spindles, stock front springs, stock brakes front and rear.
factory front springs $30 pair
factory SS rear shocks $30 pair
no rear springs or front shocks
Old Dec 24, 2009 | 03:20 PM
promod1955's Avatar
updated!!
Old Dec 24, 2009 | 08:35 PM
QK2STRK's Avatar
Is your price for both front calipers and rotors?
Old Dec 24, 2009 | 08:53 PM
Rick Speed's Avatar
how much for the 98 engine cradle with pedastols and tank with pump/sender shipped to 44135
Old Dec 24, 2009 | 10:45 PM
bill12690's Avatar
thanks, lol. unfortunately i'm about to spend $400 on tires. apparently "more important"...who knew. I've really been wanting to get LT's with TD's and CME out the back...
Old Dec 24, 2009 | 11:57 PM
promod1955's Avatar
yes it is
