Strange shocks & madman transverse mounts
S5070
New in box, never mounted or anything strange. Double adjustable rear shocks.
These lightweight aluminum construction "bolt-in" shocks are based on the proven Strange coil-over technology. Strange's rear shocks feature easily accessible external extension (single adjustable) and compression (double adjustable) tuning *****. With billet steel cross bars and polyurethane bushings, these shocks provide a wide range of adjustments. They are 10 way adjustable on compression & 10 way adjustable on extension. Ideal for street and track. They also have a updated smaller offset extension **** for added sway bar clearance, A problem with some other shock styles.
http://www.madmanandcoracing.com/sho...spx?itemid=149
For '93-'02 F-bodys, these are over $510 for a pair shipped.
Selling the pair new in the box $470
Also have are pair Madman lower shock mount new. Must needed if you have a adjustable torque arm or a lowered car.
http://www.madmanandcoracing.com/sho...aspx?itemid=11
Madman's Rear Lower Shock Relocation Bracket allows for proper orientation of drag race shocks. Once installed, pinion angle adjustments can be made without putting the bottom of the shock in a bind and thus damaging the shock - a common occurrence with the F-body suspension. Also always you to place the lower shock mounting position around. For added room often needed with aftermarket swaybars, anti roll bars. And rear end housing bracket styles.
Kit comes complete with weld-on shock mounts and Grade 8 hardware.
Selling these with the shocks for $500 with the shocks, that getting them free.
