LS2 Injectors,SX fuel pump, Aeromotive 13202 regulator,6.0 truck manifolds + more
Category: Accessories
Price: $0
Location (State): SC
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9
SX Fuel pump p/n 18203 $175
Supports carbureted engines up to 1300 HP and fuel injected engines up to 1000 HP at 45 PSI
Ultra high-flow rates exceed: 80 GPH at 12 volts and 45 PSI, AND 120 GPH at 12 volts and 10 PSI
Flow-thru design maintains maximum cooling, produces outstanding reliability, and provides consistent fuel delivery from idle to full throttle
-10 AN inlet/outlet fittings for easy installation
Can be mounted inside fuel cell or external
For use with gasoline or alcohol fuel systems
For race or marine use only
Not for use with reduced sulfur content diesel fuel
New Aeromotive 13202 fuel pressure regulator with feed and return fittings. SOLD!
Pair of 2004 6.0 Chevrolet truck manifolds (non egr) Perfect for LS turbo setup. $75
Intake, TB, injectors and fuel rail off of 2000 Chevrolet 2500 HD 6.0 SOLD!
Maximum Motorsports Full length sub frame connectors 94-04 Mustage NEW! $75
Geez dude...By the time you typed that message you could have went to MM site yourself ....I mean honestly ....Why ask me the question if your going to second guess me and look it up anyway....
I know when I'm interested in something that is for sale I do my own research on the item. The person selling the item will tell you almost anything for a sale.
check it out..
http://www.maximummotorsports.com/
check it out..
check it out..
check it out..
DM
