Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Performabuilt 4l80, stall, BMR crossmember
Old Jan 19, 2010 | 02:22 PM
PowerShift408's Avatar
Default Performabuilt 4l80, stall, BMR crossmember
Category: Drivetrain
Price: $3250
Location (State): KY
Item Condition: Brand New
Re-listing this for what I think is a steal of a deal. The tranny has zero miles on it. The reason for this is that mid-build, my goals went from building a fast street car to building a race car, so I am currently running an ATI powerglide.
The Performabuilt 4l80e has the Moroso shallow pan, a Rossler transbrake, and Lokar flexible dipstick. I will give up the tranny by itself for $2800 shipped.
I also have a Performabuilt 4k stall to go along with it. $500 shipped takes it.
The BMR conversion crossmember is for 98-02 F-bodies. $175 shipped for this.
If you buy it all together, $3250 is your price.
Old Jan 19, 2010 | 04:43 PM
I am open to offers and trades as well everyone.
Old Jan 20, 2010 | 04:14 AM
rcsfastmonte's Avatar
is the trans a man shift or electronic what about the valve body reverse or forward shift?
Old Jan 20, 2010 | 07:42 AM
built408's Avatar
have any more info on the converter? billet front cover?
Old Jan 20, 2010 | 09:33 AM
sebss's Avatar
pm sent
Old Jan 20, 2010 | 05:04 PM
There are a few people wanting some more info about the tranny, this is straight from Performabuilt:
This is our strongest transmission offering to date. We start with only late model cores for our performance line and application based core for our heavy duty line (Heavy Hauler). Each of these units features all the latest upgrades and high quality materials for assembly. Below is the breakdown of the builds. Note the differences between the HD and Performance versions. The Heavy Duty line is available in both 2 and 4WD. The Performance and Heavy duty 4L80E.
The unit is disassembled, each part carefully inspected and clearances are measured to meet our specifications not just the maximum clearance allowed by GM.
The case is carefully inspected, cleaned and re-inspected. Then it is coated with a special heat and oil resistant paint making for a very tough finish and a clean look.
Bushings are replaced and sized as needed to performance specifications.
The intermediate clutch sprag consists of an extreme duty 34 element sprag and roller assembly with specially prepared race and spiral ring, to prevent high RPM snap ring release.
The Forward and Direct clutch frictions are replaced with heavy duty performance frictions. The drums are then modified to accept additional frictions and the apply area it self is altered to allow use of the entire piston area for apply in the forward drum. "Dished" cushion plates in these units are replaced with the TH400 style plates for additional reliability. These modifications will also result in a much firmer apply into gear from neutral/park to reverse/drive. But durability is significantly increased.
For the Intermediate, Direct and overdrive clutches we use the Raybestos Stage 1 Performance Frictions. These frictions exceed anything on the market for Performance Street/Strip and Heavy Duty applications and are more than suitable for any application.
The intermediate overrun band is replaced with a heavy duty unit. This is mostly valuable in heavy duty truck applications, since this band is used to hold back when the transmission is manually put into 2nd gear while descending steep grades, etc. It will hold up significantly better to engine braking.
The low sprag is replaced with a heavy duty type and the LOW/REVERSE band is replaced with either a Performance band, or a heavy duty band for our heavy hauler applications.
The Pump is carefully inspected and reconditioned for maximum durability and pressure. Special modifications are made to increase cooling and planetary lubrication.
Our own PerformaBuilt shift kit is installed in the valve body. This kit is custom set to the type of unit purchased. The Heavy Duty setup is for maximum hold with minimal "shift shock", while Performance units are set for a more aggressive race feel, while maintaining a progressive shift that increases in firmness as you add more throttle."
Each unit comes with a PerformaBuilt warranty according to the terms listed on our warranty page.
As with our other units, no core return is required. However, if you wish to return your core to us, we will purchase it and arrange return shipping
If you are replacing a 4L60E or 4L65E with this unit, we are interested in purchasing those cores as well.
Unlike our other units, 4L80E transmissions must be shipped by truck freight. While shipping is still included in the transmission price, you must have access to a loading dock and/or a forklift to receive this unit.
This unit also features many other modifications for performance and durability, which help it achieve its 1000 plus RW horsepower capabilities. This transmission will take whatever you can dish out and we guarantee it! You won't find a better unit anywhere. And, with our customer service and the staying power, that come with a large company, you can count on us to be there when you need us.
Old Jan 20, 2010 | 05:12 PM
It is electronic, forward valve body.
It is a billet converter, 2.1 STR. If you want to know anything else, just let me know.
Old Jan 21, 2010 | 05:23 PM
To the top.
Old Jan 24, 2010 | 06:45 PM
Converter is SOLD.
Old Jan 25, 2010 | 02:16 PM
To the top, make some offers guys.
Old Jan 25, 2010 | 05:04 PM
If anyone has a 6.0 shortblock or long block, I'd be interested in working out a trade for that. My truck's 6.0 laid down on me the other day.
Old Jan 26, 2010 | 05:01 PM
Bump it up.
Old Jan 27, 2010 | 02:57 PM
$2800 shipped for both the crossmember and tranny!
Old Jan 28, 2010 | 04:54 PM
Daily bump w/ a price drop! $2500 shipped for it all.
Old Jan 29, 2010 | 10:39 AM
Mid day bump, show me what you've got.
Old Jan 29, 2010 | 10:58 AM
Joshiedoom's Avatar
Bump for a local guy and for performabuilt.
Old Feb 2, 2010 | 02:55 PM
lmt0705's Avatar
1800.00 shipped?
Old Feb 2, 2010 | 08:05 PM
No thanks.
Old Feb 7, 2010 | 01:26 PM
Super Bowl Sunday bump. Pierre Garcon has 15-1 odds as the Super Bowl MVP. Take a long shot on him, win, buy my transmission.
Old Feb 8, 2010 | 07:06 PM
KHShapiro's Avatar
is te warrenty transferable? how did you ask them to set your shift points?
