House Clean Out!! Gaskets and MAF's galore!!
Category: Accessories
Price: $0
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): PA
Item Condition: Used
Engine: LS1/LS6, LT1/LT4
LS Engine?: Fits LS Engine
Pay attention to quantities, if its not written that means there is 1, if it says x2, that means 2 are available.
New Universal Trans Cooler - Don't know make, but it came with a performabuilt trans - SOLD
New 3 bolt 4x timing gear 12586481 - SOLD
New 58x crank reluctor wheel - $20
Used 85mm SLP MAF - Has pigtail for LS1 connection and has a hole drilled where a nitrous nozzle was - SOLD
Used 85mm GM MAF - $40
Used LS1 stock MAF - Small piece missing where connector goes, but still retains harness - $35
NEW GM Clutch Master 12570277 - SOLD
New LS2 timing chain 12586482 - SOLD
New Trick Flow TFS 7.7" pushrods - $60
New Crank Bolts x2 12557840 - $5 each
Used Flat 4 wire O2 sensor extension - $5
New Square 4 wire O2 sensor extension - $5
New LS1 to LS2 knock sensor conversion harness - SOLD
New LT1 Valve Cover Gasket 10046089 - $5
New LT1 Throttle Body Gaskets x2 10105379 - $5 each
New LS1 Intake Manifold Gasket Kit Fel-Pro MS92438 - SOLD
New FAST 90mm Throttle Body Seal - $2
New LS1 Coolant Crossover Seals x4 12551933 - SOLD
New LS1 Oil Pump O-ring 12557752 - SOLD
New LS1 Water Pump Gaskets x2 12588372 - SOLD
New GM Pilot Bearing 14061685 - $2
Used 78mm Throttle Body Gasket - $5
New LSx Valley Cover Gasket 12574467 - SOLD
New GM MLS 5 layer head gasket 12610046 - SOLD
New GM LSx Valve Cover Gaskets x4 12560696 - $5 each
New LSx emissions tube seal 12557932 - $2
New GM L92 Crank Key 12561513 - SOLD
All PM's replied to with the same thing...
www.ups.com
All parts are coming from 19026...I'm pretty sure ya'll can guess on weight and figure shipping. Sorry guys I hate to be a jerk but I can't do 10 million quotes on shipping.
www.ups.com
Anyone that wants to negotiate on a $2 gasket don't waste my time or yours please...It's obvious that you have money issues and the last thing you should be spending your last dollar on is a gasket. Also please RE-READ the thread and understand that I will not ship anything USPS. Especially not in an envelope with stamps on it.
