Billet fuel rails and braided lines, March 25% UD pulley, lots of stock LSX parts
Category: Accessories
Price: $225
Location (State): TX
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9
I have a bunch of parts FS, will list a few here and a global of the other parts if your interested. Some pictures can be found here:
http://s464.photobucket.com/albums/r...anvey/?start=0
To start, I'm always looking for the following for a trade/or to buy:
Full accy from a CTS-V or a Corvette LS1/2/6
Dipstick from a F-body
My FS items:
Aftermarket parts:
Red anodized Billet fuel rails - was on a LS2/3, but had LS1 stock injectors in it - should work for LS1/6/2/3.
Fuel rails have threaded opening on both sides. I have a set of braided stainless lines coming from both sides to a NOS labeled Y to a single hose that went to the FPR,(not included). There is then another ~4ft hose from a FPR to the fuel line under the car. The two lines from the rails have 90 deg connectors and the adapters into the end of the rail. The Y goes into a 45 deg hose connector and ~1ft of line. The free 4ft hose is has a 90 on one side, nothing on the other. Pictures are in link above. Was installed in a 2001 Camaro.
$225 shipped
Stock parts I'm working on another thread with these, but wanted to move the aftermarket parts first.
From a 2005 Trailblazer SS 6.0 motor with 27k miles on it:
2005 TBSS 6.0/LS2 ECU $75
A/C compressor and bracket - all bolts and tensioner pulley $75
Stock pushrods for LS2 6/0 motor, in excellent shape $50
Water pump with big electronic clutch assy,(removed). No
thermostat/housing $75
Flexplate $20
engine mounts, the metal part, no rubber $10
stock LS2 camshaft $50
F-body parts:
Oil pickup for LS1/F-body pan $40
T-56 crossmember $25
T-56 Torque arm mount $10
F-body stock shifter arm,(the one that bolts to the shifter, no ****) $10
-Bob
Pictures posted here:
http://s464.photobucket.com/albums/rr9/rehanvey/
UD pulley and belt - I'm pretty sure I don't have the belt anymore - I will check and post if I do, but I don't think so.
Ok, got the pictures for the pulley. The part number on the pulley is PRW-4521 (the 4 on the back is slightly obscured in the picture, but you can see it on the back in the other picture).
hey if you still got the p/s and alternator bracket, and the tensioner and all the bolts how much for those since the tensioner was priced in with ac compressor and i dont need that? forgot to mention i would also like the crank pulley too!
I'll assume you are talking about the truck accy..
PS on the truck,(of note, the small return nipple on the bottom of the reservoir is broken off - I can fix it with a brass nipple), the alternator bracket that the PS is bolted to/and the bolts. I do have the separate tensioner - but that is not what I was talking about on the PS/Alt bracket. There is an idle pulley at the top of it.
Basically the part on the right of this picture:
http://s464.photobucket.com/albums/r...rrent=Accy.jpg
For that shipped to - well, I don't know where you are.
Well, price above for that was $50. Shipping is going to be at least $15, more like $20 for a part that big,(depending on where you live).
So for that part, I'd say $60 shipped.
I assume the truck parts are what you are talking about - since I didn't group the items you asked about.
-Bob
Oh, and for others, the tensioner is the A/C tensioner - the small one self contained on the bracket. Not the big tensioner.
-Bob
