Speed Inc Shims, Hamlet check valve , stock ls1 stuff, tial wastegate and bov springs
Category: Racing Parts
Price: $0
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette
Location (State): FL
Item Condition: Brand New
Engine: LS1/LS6
(1) Hamlet check valve 1/3psi cracking, all stainless great for PCV catch can. $30 shipped does not include blue AN fittings, pics at bottom. $50 if wanted with the 4 Earls fittings. You wont find a better and stronger check valve
(1) NIB Set of Speed Inc Valve Spring shims. This kit has 16 shims of each .060, .030, .015 thickness $18 shipped Set your valvetrain up right!!
(1) 01 LS1 stock camshaft with 30k miles looking clean.. $22 shipped
(8) LS1 stock rods and pistons, still hung, pistons are toast, rods have been checked by machine shop and are good to go out of my 30k mile car. $45 shipped
(1) LS1 Valley Cover $20 shipped
(1) 01 LS1 Washer pump tested and came out of 30k mile car $15 shipped
NEW Tial 38mm Wastegate Spring (SMALL RED) 5.802psi spring, used for one pull and replaced as needed a bigger to obtain psi goal. $18 shipped
New Tial 50mm BOV Spring (Unpainted) for use with vacuum reading at idle between -18 and -21 in/Hg , this was used only for startup and found I needed smaller spring as vacuum was -15 in/Hg. $18 shipped
(1) New in package Fragola Black -10 AN push to lock barb fitting, good for oil return $10 shipped
(1) NIB Earls 3/8 npt to -6 hose fitting #820166erl $8 shipped
