Nitrous parts 4 sale
Category: Racing Parts
Price: $1
Location (State): KS
Item Condition: Used
Y fitting 1/8 npt x 3an x 3an new 1-red & 1-blue $10 each (SOLD)
NX Shark nozzle new $20
Nitrous Express bottle opener motor with clutch $40
Blowdown tube 180 degree new $10 (SOLD)
3 solenoid or tps brackets new $2 each
Nitrous Express jets 3 #18, 2 # 41, 2 #52, 3 # 62 new $2.50 each
Bottle heater pressure switch (transducer) adjustable pressure 500-1,250 psi 1/8 npt with instructions $25 (SOLD)
6an hose 3 ft. with 90 degree fittings on both ends $15
safety valve 3,000 psi new $5 (SOLD)
2 each 4an plugs $2 each
4an cap new $2
fitting 3an x 1/8 npt $2
3an hose new 2 ft 2 each with red fittings and 2 each with blue fittings $10 each
4 an male union $2
Adapter manifold 2 each blue 4an x 4an x 1/8 npt x 1/8 npt $ 10 each
Also if you have trouble with leaking AN fittings the round orange seals will seal leaking AN fittings. I have them for 4, 6, & 8 AN
Thanks for asking. I only have the motor & clutch as in the pic. You would need a switch & relay which are not expensive. But you would also need the parts that attach to the bottle valve. They are the purple parts in this link. Click on the image for a blow up. http://www.crossroadzdirect.com/nxs-11107.html Possibly you could find someone who has one with a bad clutch & motor.
Terry
Terry
I don't know for sure. You might want to call Nitrous Outlet or one of the other vendors. The thread size is 1-1/8" fine thread (12 threads per inch) and the tube measures 14-3/4" long starting at the bottom of the threads. It uses an 0-ring seal at the top of the threads.
