2001 6.0L fuel rail ?
Old Mar 13, 2010 | 03:22 PM
millwright1999's Avatar
Default 2001 6.0L fuel rail ?
I have a 2001 6.0 LQ4 that I want to change my fuel rail. My current rail has the inlet and return lines, I would like to change it so I just have a feed line so I can use a Warbro pump wit vette filter reg. Does anyone know what year or what engine will fit the stock intake and have no return line. I am trying to go the least expensive way possible so I do not want any custom aftermarket rails. Any help or ideals would be great.
Old Mar 13, 2010 | 06:42 PM
gofastwclass's Avatar
Depends if you are using the stock truck intake or switching to a car intake and injectors.
Old Mar 13, 2010 | 07:43 PM
ls1nova71's Avatar
I'm pretty sure 2004 is when the trucks all went to the single fuel line, so anything newer than that should be what you're looking for.
Old Mar 13, 2010 | 08:02 PM
thedrill's Avatar
I have a 2006 4.8 truck engine with the single fuel rail and I want one with the return line.. does anyone know if they will interchange?
Old Mar 13, 2010 | 08:04 PM
04600rr's Avatar
to answer both questions....yes they will interchange...and 2004 up trucks should be returnless
Old Mar 13, 2010 | 08:05 PM
thedrill's Avatar
If Millwright1999 wants to swap, Im happy to do so.
Old Mar 13, 2010 | 10:06 PM
Yes I want to keep the stock truck intake.
Old Mar 13, 2010 | 10:08 PM
I might be interested in a trade, PM me.
Old Sep 17, 2010 | 06:12 PM
chuckd71's Avatar
When swapping from return to returnless or vice versa do you have to do anything else? Do you need a retune or anything? I want to go to a returnless setup on my truck intake.
Old Sep 18, 2010 | 02:50 PM
NemeSS's Avatar
why do you want to go that way?
Old Sep 18, 2010 | 04:33 PM
chuckd71's Avatar
Right now I have an 02 truck setup, but I have found a rails/injectors setup from an 8.1 that I would like use. I would also prefer to just have to run the one hard line up and down the car. It's not a 'must do' thing, it would just simplify things a bit.
Old Sep 20, 2010 | 08:20 AM
Jim_PA's Avatar
I have an '04 Yukon with a 5.3, and an '04 6.0 from a 2500 truck, both have the return-style fuel rails. The returnless rails are a direct fit, but I'm thinking it's more like 05+. I just put mine on the 6.0 for the same reason:
70 micron pre-filter -> walbro pump -> corvette style filter/requlator, and only one line going up to the fuel rail.
Old Sep 20, 2010 | 03:55 PM
chuckd71's Avatar
That's what I want to do, I just wasn't sure what parts of the fuel system the computer sees or if you could just swap rails at will.
