LS1 Block, Crank, 918, Pistons, Rods, Hawk Pads, Calipers, Rotors, Etc !!! w/Pics
Category: Engine - Power Adders
Price: $199
Location (State): FL
Item Condition: Used
Also look at My Sig for the links to the rest of my Sales !!!
Prices are plus shipping and 3% Paypal.
LS1 Block - SOLD !!! (need it out of my garage so make your offers)
Going to 408 so this has to go, it was 3.905" but the machine shop did a cleaning hone so it should be 3.907 now.
I have a lot of pics so let me know if you want more !!!
LS1 Crank 12552216 (It's cut .10/.10 and polished so it's ready to go) - SOLD !!!
(I also have the Main and Rod Clevite Bearings if you want them too, all this was just mounted for 1 hr so it's like New)
Comp Cams 918 Springs 5K miles - SOLD!!!
Beehive Shape Ovate Wire Springs
The 26918 Valve Springs are specifically designed for the LS1 Chevrolet cylinder head and can be used as stock replacements or in performance applications all the way up to 0.600” lift and at engine speeds to 7500 RPM. Engineered to fit stock heads with no machining, utilizing the stock valve seat and spring retainer. This valve spring can also be used in all applications with the specifications list-ed.
Installed Load: 125 lbs @ 1.800"
Open Load: 348 lbs @ 1.200"
Spring Rate: 372 lbs/in
Coil Bind Height: 1.110"
Outside Diameter: 1.290"/1.060”
Inside Diameter: .885"/.656”
Part # 26918-16
Description GM LS1 Spring High Load Spring
http://www.livernoismotorsports.com/...t.phtml?p=1717
LS2/LQ9 Pistons Full Floating Pins (Only 7 ) - $29 Each !!!
LS2/LQ9 Rods (Full Floating Pins) - $25 each!!!
Motor Mounts (Ready for Poly Mounts) - $60 !!!
LS1/LS6 Pistons/Rods Low miles - $145 Obo!!!
LS1/LS6 Piston/Rod Low miles - $25 each !!!
LS6 Thermostat - $18 !!!
Poly Bump Stops NEW (Bought from a member here but never install them) - $48 !!!
Brand New Mr. Gasket Exhaust Gaskets Ultra Seal for LS1/LS6/LQ9/LS2/Etc - $18 !!! (I paid almost $35 for them...)
LS1 Coils - $18 each !!!
97-08 Corvette and 05-06 GTO Front Hawk Pads NEW (HB247F.575) - Only $99 and FREE Shipping!!!
SLP **** - $45
O2 Sensor "AC AFS 98" 16" long - $28 Each
a
O2 Sensor "AC AFS 97" 12" long - $24 Each
A/C Evaporator - $25
Accessories and A/C Belts Low Miles - $29
Stock SS Tailpipes / Tips - $34 !!!
LS1 Intake with Plug - $55
EGR Pump and Lines - $55
AIR System Pump and Hoses - Make an offer !!!
SLP **** - $45
a
Package Deal = Front/Rear Calipers, Front/Rear Rotors and Front Pads - $220 !!!!
LS1 Front Calipers $89 - "Rear SOLD"
Grinded LS1 Front Calipers (To Clear Drag Wheels) - $100 !!!
Stock Font Pads (tons of life left) $40
Set of GM Camaro LS1 Rotors "READY TO USE" Front or Rear $69 each set "FREE SHIPPING"
LS1 Roller Rockers - $7 each
Oil Pan Tray - $15
Radiator Hoses - $9 Each (lONG SOLD)
Throttle Position Controller / Sensor (GM 10426909) - $69
Brake Hoses $18
Brake Master Cylinder $40
Brake Lines from Master to the Block - $15 each
ABS Brake Block - $50
Cruise Control Module - $79
10 Housing with Relocation Brackets Weld in $50
10 Bolt C-Claps Axel holders $12
LT1 Front Calipers RED with CAMARO on them - $55
LT1 Performance Pads - $38
Front Drilled LT1 Rotors - $60
LT1 Spindles - $40 Each
Oil Pan Tray - $15
Brake Hoses $18
