LT1 Parts! Anything you need!
Category: Wheels & Tires
Price: $15
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette
Location (State): NE
Item Condition: Used
Engine: LT1/LT4
(1) M6 Radiator - $50
1 Pair of AC Delco o2 sensors with only 3k - $50
(1) Set of F-body fuel rails - $25
(1) Set of 7 stock 94-97 LT1 Injectors - $20
(1) Accessory Bracket F-body - $25
(1) Stock Camaro Starters - $25
(3) 95 LT1 Timing Covers - $65ea
(1) Vented opti Harness - $15
(1) Vented Opti Vac Lines - $15
(2) 92-94 Timing Covers - $20ea
(1) NEW 92-94 Timing Cover $30
(1) OBD 2 PCM's (96/97) - $45
(2) LT1 Altenators - 40
(2) F-body ABS Block - $35
(1) Set of A/C lines - $40
(2) A/C Condensors - $20ea
Perfect M6 Flywheel, turned 5k ago, have correct shim, bolt in and go - $50
Drivers 94 Camaro taillight - $25
Ebony Carpet, Complete, No Holes or damage. Decently clean - $45
Rack/Pinion from a 94 w/ 89k - $50
Misc Plastic Interior parts - $20ea
Drivers/Pass Airbags - $35ea Pass sold!
Upper Radiator support cover - $15
A4 Trans Bracket-$25
M6 Trans Bracket - $25
Brake booster/master cylinder - $40
M6 Pedals - $75
Stock 93-96 A4 console. Good condition (needs a lid but the hinge is not broke on the console side) - $70
Stock complete Fuel lines - $50
Oil pump driveshaft - $35
Waterpump driveshaft/gear/bearing - $25
93 ECM/PCM, F-body - $150
Stock 93 M6 3.23 BDLD PROM - $100
Complete 98-02 Trans Am Rear Taillight conversion - $300
Complete 93-97 Front headlight buckets/motors - $150ea side or $250 for both sides
Oil pan with rails - $35
Stock T/A 93-96 Cd player (from a 95) - $65
Stock BOSE 94/95/96 Cd Player - $175
Performance
MAF Translator for LT1/LS1/Grand National - $125
Autometer 2 5/8" Sport Comp trans temp gauge (perfect size for T/A vent holes) - $35
http://www.summitracing.com/parts/ATM-3552/
LT4 ED Timing Set - $150
Kooks 1 3/4 to 1 7/8" Stepped Stainless Headers and Stainless Y-pipe. O2 extensions, header bolts, clamps, and even good used Kooks Header gaskets if you want them - $1100 shipped
ARP Head Studs - $100
CSR TH400/TH350 Sheild, SFI Approved - $250
2.75" Chromoly driveshaft for TH400 & 12bolt/10bolt, 1350 ujoints, 43.5" center to center - $275
Prothane poly trans mount - $15
AS&M 58mm TB w/sensors & bolts - $375
Stock V/Cs clearanced for 1.6 roller rockers - $35
Eibach Drag Launch Spring Kit, $175 PENDING
ATI Super Damper F-body Part # 917270 - $250
LT4 mini starter - $100
LT1 Granatelli MAF - $150
Moroso CAI - $120
K&N CAI - $120
SLP dual filter matt black CAI - $150
Custom aluminum fabricated 4" CAI, nicest of any ive seen for an LT1 camaro, (will not work with abs equipped cars unless you install an abs delete kit) - $175
CSI/R Electric Water Pump already mounted into an F-body w/p housing with 160 thermostat- $135
Morel Link Bar Hydraulic Roller Lifters, best money can buy - $375
Battery Relocation kit with Flaming River cutoff switch/handle, was over $300 for everything new, Aluminum battery box - $175
Battery Relocation kit without cutoff switch, plastic NHRA approved vented box - $75
Custom stainless switch panel for the area where the radio is removed from with some switches already included - $40
44# Bosch Injectors - $200 PENDING
Powerslot front/rear rotors with 1k - $225 (were $430 new)
LT1 1k mile old front brake calipers and pads (gm ac delco pads) - $75
MSD Digital 6 Ignition with 8876 msd harness for direct plug and play with 93-95 LT1s - $200
Trickflow 7.1" (custom length for milled LT1 heads, or etc) Hardened Pushrods - $60
Comp Cams 'r' series 875-16 Lifters - $120
Brand new in the box Comp Cams Solid roller lifters for LT1 & Late model 87+ SBC PN#888-16 - $300
http://www.summitracing.com/parts/CCA-888-16/
AKM OBDI molded Cable for 93-94 F-body, serial port - $50
All body parts are red and will extremely expensive to ship except a fender-
93-97 Camaro Hatch with glass intact - $75
93-97 T/A bumpers - $85ea FRONT SOLD
93-97 T/A Doors with brand new window motors - $150ea DRIVERS SIDE SOLD
T/A Cluster with 97k on it - $30
150mph Z28 Cluster with 141k on it - $30
EB Ported Heads & Intake (Flow 278/191 Peak) & Joe Overton Cam - $1600 (PM for details)
Golen Built Competition 383 4-Bolt Forged Shortblock, PREMIUM BUILD w/10k - PM for details $2250
Pics of the radiator? If its good condition w/no leaks Ill take it
schambersiv@hotmail.com
Steve Chambers
Steve Chambers
You all have pms...
artrenee10 ill have to grab some pics of the radiator today while im at the shop. It has no leaks and is only 1500 miles old actually. Very good condition...
Steve Chambers
Well they are different but the difference is that the A4 has fitting for the trans lines. If you don't need them you just don't hook them up. An M6 radiator won't work with an A4 but the other way around is fine. This is from an auto so yes it will work with your M6 car with no problems.
