Old May 2, 2016, 01:17 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevrolet Camaro or Pontiac Firebird Interior Guides
Print Wikipost
My BLS HID kit install! (56K go away)
Old Apr 17, 2010 | 04:22 PM
skorpion317's Avatar
Default My BLS HID kit install! (56K go away)
I received my BLS HID projector kit yesterday, and got to install it today. The install was nice and easy. The parts are all high quality, and the plug-and-play wiring harness is great. Here's the pics from the install:
The contents of the kit:
The white boxes contain the HID ballasts and bulbs. The yellow boxes contain the Hella projector housings. The mounting plates are on the left hand side - Brian did a great job on these!
Here is the passenger side, with the low beam removed.
This is the stock headlight, after disasembly.
The passenger side projector, bolted into the mounting plate.
The projector, now with the black plexiglass panel covering the mounting plate, and the foam sealing strip attached.
The passenger side headlight, fully assembled. It reuses the stock trim ring to hold everything in place.
Here's how I mounted the wiring harness. The relay goes in the empty space by the fuse panels, where it is zip-tied to the piece of metal with the rubber hood cushion in it. The power cable is routed underneath the fuse panels, and connected to the positive terminal to the left of the top fuse panel (the one with the red cover). The ground cable is also routed underneath the fuse panels, and connected to the negative terminal on the support to the left of the bottom fuse panel.
Here's the passenger side headlight wire, which I routed along the wiper fluid tank.
Here's where I routed the driver's side headlight wire. It goes through the space between the support and the small frame with the bolt in the middle of it, then comes out underneath the frame.
Here's the wiring harness, with the power and ground cables connected.
I mounted the ballasts inside the front bumper. There's a part of the bumper support that is kind of like a little shelf. I cleaned it off well and installed the ballasts using the industrial-strength Velcro mounts provided.
Old Apr 17, 2010 | 04:25 PM
Soul TKR's Avatar
very cool! I'm jealous!
Old Apr 17, 2010 | 04:26 PM
This is the passenger side headlight assembly getting mounted back up.
Clearance is good!
Here's both headlights installed.
A closer front shot.
From the side.
Moment of truth! They work great!
It looks pretty mean!
Old Apr 17, 2010 | 04:30 PM
This pic is with the camera more in the path of the lights.
I'm really happy with these, and I haven't even tried them at night yet! Brian did a great job on this kit. I'm very impressed. I highly recommend this kit to anyone who wants HIDs for their 98-02 Firebird. I still have to adjust the lights, but I have to wait until nighttime to do so. I'll put up more pics after I get them adjusted.
Old Apr 17, 2010 | 04:45 PM
BLSolutions's Avatar
Looks great! Excellent pics. Check your PM inbox.
Old Apr 17, 2010 | 05:45 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
What bulbs did you go with? I'm trying to make up my mind on that.
Old Apr 17, 2010 | 06:39 PM
Trans Am Jam's Avatar
looks sweet. post up pics of them at night.
Old Apr 17, 2010 | 11:00 PM
transam5.7lt1's Avatar
What color temperature did you choose? Those look great!
Old Apr 17, 2010 | 11:31 PM
I went with the 5000K kit. I wanted an OEM-style look. I think it looks really clean.
Without further ado, here's the night pictures:
I think I got them lined up correctly...
These pics are on the street:
And last but not least, some video:
http://s17.photobucket.com/albums/b1...ent=hid034.flv
The HIDs are awesome. They light up the whole road. Driving in the middle lane on a 3-lane highway, all 3 lanes were lit up. It's nice to be able to see clearly for once.
I installed the springs on the adjustment screws wrong, which made it hard to adjust the lights. I'm going to fix that tomorrow, and get more pics.
Old Apr 17, 2010 | 11:41 PM
getting close to that 80k mile marker ;] they look great. get a better camera and take pics of them w/ the bezels and a car wash haha
Old Apr 18, 2010 | 12:02 AM
It's getting washed in the morning. I have to fix the bezels too - they're a little off for some reason. They're closer to the bumper than they were before, which is kind of weird.
Old Apr 18, 2010 | 12:06 AM
I'm also going to switch to LED turn signals and fog lights. I have clear incandescent bulbs in the turn signals, and they're still kind of yellow. I can't stand yellow lights.
Old Apr 18, 2010 | 12:10 AM
MYSTIC-1SC's Avatar
very nice.
Old Apr 18, 2010 | 12:15 AM
black_sheep454's Avatar
Looks great man
Old Apr 18, 2010 | 01:40 AM
Night shots look great! Love the shot of the cutoff.
Old Apr 18, 2010 | 02:20 AM
SS#502's Avatar
Where did you get these from? I wonder if your lights are the same size as the Camaro?
Old Apr 18, 2010 | 04:31 PM
I got them from Blackbird Lighting Solutions, one of the great sponsors of this forum. The 98-02 Firebird's lights are not the same size as the 93-97 Camaro's lights, so these won't work for your application.
LooksSweet1's Avatar
He got them from Blackbird Lighting Solutions. (The guy that posted above you.)
No, the '98-'02 Firebird lights (150 x 92 mm) are bigger than the '93-'97 Camaro lights. (140 x 64 mm)
Chris
Old Apr 18, 2010 | 06:19 PM
HoLLo's Avatar
Awesome!
Old Apr 18, 2010 | 08:10 PM
OWN3D BY MY PROF!
They look like laser beams. Are they aimed a little low? I honestly have no clue. I'm not used to having that kind of an absolute cut off. What are you doing for the fog lights? I am going to put new ones in my Formula once I get it back together. All of mine are cracked, take in moisture, and above all else none of them work. I bought a set of OEM C6 / ballasts lights that I think are the right size to rig up as foglights in the Formula holes. I haven't messed with it yet as I just got the lights yesterday and have been working 16 of the past 24 hours.
EDIT: I really am starting to lean towards the 500k selection. I was between that and the 600k, but I'm still not 100% sure.
