Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
2000 Camaro Vert Part Out
Old May 4, 2010 | 10:33 AM
Stark's Avatar
Default 2000 Camaro Vert Part Out
Category: Engine - Exhaust
Price: $0
Location (State): GA
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
I've decided to part out the vert and not go through the headache of trying
to re-build a twisted frame car. I have a thread in the vert section, "Fix her or walk away", that shows the frame damage. That being said, there are still alot of good parts that need to go to cars that will be driven, so the vert lives on.
I have a short list of parts and pictures that i'll continue to update this first post as i take more of the car apart. If the items are listed with a firm price, then don't pm me a lowball offer, i will ignore you. Otherwise, feel free to offer sensible offers on the stuff you see and need.
Please add the 3% to the price for paypal.
I will accept money orders as long as they show up no more than 5 business days from the day you tell me "it's in the mail". Otherwise, i'll re-list the item.
Please tell me your zip code for shipping quotes, shipping is not included in the prices i have listed.
If there are items for the vert top stuff not list, post up what you need.
I'd like to sell the whole vert top "complete" first.
If not, a few people have already asked about different parts of the assembly so i may divided it up as long as all the main parts are spoken for,(ie, canvas top, back glass,headliner, pump, etc.)
Engine / Drivetrain
LS6 Intake w/coolant lines $300.00 SOLD
Oil Pump (thunder racing) $100.00
Timing chain (SDPC) $25.00
Sparkplug wires (MSD) SOLD
Sparkplug wire socks (WCC) SOLD
Stock Throttle Body w/sensors SOLD
26lb injectors SOLD
Fuel rail SOLD
MAF (screen intact ) SOLD
PCM (with tune) SOLD
F13 cam 230/232 .595/.585 SOLD
Stock cam $25.00
Pushrods (futral 7.400 .080) SOLD
Waterpump w/ stock thermostat $85.00 SOLD
Flywheel SOLD
Motor mounts $40.00 SALE PENDING
853 heads SOLD
Valve springs SOLD
Rocker arms SOLD
Oil Dip Stick SOLD
Lid with baffle (stock) $25.00 SOLD
LS1 wiring harness SOLD
T56 six speed trans $500.00 SOLD
Drive shaft SOLD
Windshield washer reservoir $55.00
Line lock w/brake lines SOLD
Bellow-intake SOLD
Clutch master cylinder w/reservoir SOLD
Hurst shifter (stock) SOLD
Upper/lower shift boot SOLD
MGW shifter SOLD
Coil Packs (4) coil packs left- NO brackets $40
Clutch (stock) SOLD
Bellhousing SOLD
Starter SOLD
Stock lifters with trays $55.00
Alternator SOLD
Valve covers SOLD
Gas/Brake/Clutch pedal Assembly $50
10 Bolt rear end 3.42 gears 4 channel $250 LOCAL SALE ONLYBust up your rear at the track? Swap with me so the vert can roll to the grave yard. No issues with the rear, never had slicks, never any 5k clutch dumps. LOCAL SALE ONLY SALE PENDING
Exhaust Parts
Kooks 1 3/4 headers SOLD
Kooks catted Y-pipe SOLD
TSP true duals w/sweet thunder SOLD
Magnaflow cat-back SOLD
Weld-in cutouts 3" $40.00 PRICE DROP
Magnaflow tips 3" SOLD
O2 sensors (stock) SOLD
O2 extensions SOLD
Cut up catless kooks y-pipe SOLD
DMH electric cutouts 3" (only one works,can't remember which one) SOLD
Mufflex y-pipe hanger clamp $25.00 SOLD
Suspension & Brakes
Strano Springs Front SOLD
Strano Springs Rear SOLD
Koni Shocks front BROKEN not for sale
Koni Shocks Rear SOLD
Bilstein Front and Rear (new in box) SOLD
Bilstein Rear(used) SOLD
Strano Front sway bar 35mm SOLD
Strano rear sway bar 22mm SOLD
BMR UpperPanhard relocation bar SOLD
UMI lower control arm $125.00 SOLD
UMI adj Panhard bar SOLD
Torque arm mount SOLD
Brake master cylinder reservoir $75.00
Brake Booster SOLD
Interior(Tan) / Vert Parts
Trunk latch $40.00
Gauge Cluster $95.00
Gauge Cluster bezel $45.00
Radio (stock- everything works) SOLD
Radio bezel $55.00 SOLD
HAVC controls SOLD
Rear view mirror $35.00
Sun visors SOLD
Driver's side a-piller $45.00
Passenger side a-piller $25.00
Panel under steering wheel $15.00
Panel under glove box $15.00
Rear seat panel passenger side SOLD
Rear seat panel driver's side SOLD
Glove box latch $15.00
Headlight control SOLD
Fog light switch $35.00
"ASR" switch $9999.00 Firm
Vert top boot TAN (with case) SOLD
Vert "divider" (black) SOLD
Vert switch plate SOLD
Vert switch plate (used-with two small holes) SOLD
Door panel Driver's side $75.00
Door panel Passenger's side $75.00
Rear speakers (stock) SOLD
Front speakers ( alpine's ) $60.00
Console (upper/lower) SOLD
Triangle panel behind side mirror(drivers) $30.00 SALE PENDING
Triangle panel behind side mirror (passenger) $30.00 SALE PENDING
Exterior / Miscellaneous Parts
Wolf/ Noah camaro cover $100.00 SALE PENDING
Camaro grille (stock) $20.00
"SS" Emblems SOLD
"SS" Mats SOLD
Driver's headlight SOLD
Passenger headlight has a crack/ Bracket is still good SOLD
Turn signal light driver's side $10.00 PRICE DROP
Turn signal light passenger's side has a crack in it, sorry.
Auto X Ray scanner $35.00 PRICE DROP
Gtech $80.00 PRICE DROP
10" Boomtube $35.00
"SS" Hood "grille" insert SOLD
3rd Brake light $15.00
Windshield wiper arm Driver's side $25.00
Driver's side cowl ( black plastic ) $25.00
Trim Rubber on cowl $15.00
Old May 4, 2010 | 11:06 AM
AmPleZeMi4's Avatar
dibs on the t56
Old May 4, 2010 | 11:33 AM
Stark's Avatar
Originally Posted by AmPleZeMi4
dibs on the t56
Forgot to add a pic of that.
Ported oil pump from thunder racing
Old May 4, 2010 | 03:11 PM
shadyltd2690's Avatar
hey man how much for the complete t56 swap
Old May 5, 2010 | 08:28 AM
Stark's Avatar
Thanks for asking, the T56 is sale pending right now, and i've already sold the master cylinder and the clutch fluid reservoir so i don't have a "complete swap" to offer you.
Thanks for looking!!
Old May 5, 2010 | 10:28 AM
Ocala93TA's Avatar
do you have pics of the covert. top ?
Old May 5, 2010 | 11:23 AM
Stark's Avatar
Yes i do.
The top shows the wrinkles from the frame damage, but the top it's self is in good shape.
Old May 5, 2010 | 07:04 PM
brianfromhawaii's Avatar
got the dash still?
Old May 5, 2010 | 09:27 PM
Stark's Avatar
Originally Posted by brianfromhawaii
got the dash still?
Sorry, the dash is destroyed.
Thanks for asking!!!
Old May 6, 2010 | 12:15 AM
Stark's Avatar
Thanks for the pm guys!!
Keep'em coming!
Old May 6, 2010 | 05:28 PM
Stark's Avatar
Price drop on a few items!
Thanks for all the pm's!!!
Old May 7, 2010 | 03:56 AM
Stark's Avatar
Friday Bump!!!!
I could have sold (4) T-56 trans this week!!!! WOW!!!!
Too bad i only have one.
It's still SALE PENDING, tho.
Thanks for all the pm's guys!!!
Old May 7, 2010 | 10:08 PM
nprather's Avatar
what size are the cutouts? If they are 3 inch ill take em. only need one but i guess ill take both if you dont know which one works
Old May 8, 2010 | 01:16 AM
KING Z28 HAWK's Avatar
If you can do $55-$60 shipped to 93703 on the DMH e cutouts I'll take them! Give me your paypal info and money will be sent.
Thanks,CJ
Edit: Also does this mean two Bilsteins? "Bilstein Rear $75.00 PRICE DROP" If so how much shipped to same zip?
Old May 8, 2010 | 02:52 AM
7th Darkness's Avatar
How much for the lower air box/radiator shroud thing to 40403?
Old May 8, 2010 | 03:54 AM
Stark's Avatar
My bad.
The DMH electric cutouts are 3".
Like i said, when i last used them, only one of the cutouts opened, i didn't want to mess with them anymore so i just removed them from the car, put them in a box, and forgot to label which one worked.
I'll send you a pm.
Old May 8, 2010 | 03:58 AM
Stark's Avatar
Thanks,CJ
The post above you asked for the cutouts, so your #2 in line.
I'll send you a pm with a shipping quote.
Again, my bad.
I should have listed the rear bilstein's as used. Not part of the "new in box" set.
I'll send you a pm with a shipping quote on that as well.
Old May 8, 2010 | 04:00 AM
Stark's Avatar
The lower air box/radiator shroud is sale pending, your #2 in line.
Old May 8, 2010 | 08:26 PM
Stark's Avatar
The F13 is RE-LISTED.
Old May 8, 2010 | 09:03 PM
98PurpleT/A's Avatar
Do you still have the carpet? If so what shape is it in?, and how much?
