PARTING TURBO KIT,presicion,intercooler hot pipe,cam,timing set injectors etc
Decided to part out the kit in peices hopefully it will sell that way
410-218-1620
-PTK hot pipe all stainless V band-prefere pick up will ship $500 obo
-Presicion PT turbo, 360 race bearing .68 AR, T4 flange,race cover, polished housing no shaft play rated at 750hp $500obo comes with feed and return oil lines
-all aluminum piping and 24 T bolt clamps,all piping and couplers throttle body to turbo-- SOLD
-LARGE Front mount Inter cooler $125
-JDM bov $50
-Nitrous brand boost gauge with 5 color led changing face $50
-siemens 60# injectors for LS1 SOLD
-roller master single roller adj. timing chain set 4k miles no play $50
-TSP 7.400 push rods excellent shape $ 65
-Comp cams Turbo grind cam shaft (pm for specs) $200obo
-New set of GM 5.7 MLS head gaskets $50obo
-GM 2 bar map sensor bought new (factory application is for SS cobalt) $45
-TSP ported LS6 oil pump $100obo
-Hyper tech $160 therm $45 obo
410-218-1620 call/txt
i needto get more pics and PP is accepted..pick up of parts is fine will also ship
410-218-1620
-JDM bov $50
$250 for injectors with out turbo kit purchase..
cam specs
SERIAL # S 0023-09 SPEC CARD # 17244909 SPEC CARD INQUIRY BY SERIAL # PART # 54-000-11 CAMSHAFT, LS1 CHEVY LS1/GEN III '97-UP CORE C54-11AA CAMSHAFT BLANK, LS1 1997 UP 5.7 CORVETTE
SpecialGrind GRIND # LS1 13020R /13020R HR115.0
DURATION @ .050 INTAKE
239 ROCKER ARM RATIO
VALVE ADJ INTAKE .000 DURATION @ .050 EXHAUST 239 INTAKE VALVE ADJ EXHAUST .000 LOBE LIFT INTAKE .3670
EXHAUST VALVE LIFT INTAKE .623 LOBE LIFT
EXHAUST .3670 1.7 VALVE LIFT EXHAUST .623
LOBE SEPARATION 115.0 DURATION .006
INTAKE C/L 113.0 TAPPET LIFT INTAKE 289
CAM ADVANCE 2
TAPPET LIFT EXHAUST 289 HYDRAULIC
cam specs
CAM ADVANCE 2
