QMP Turbo Formula - 750rwhp / 830rwtq STOCK ENGINE
Old 01-22-2004, 07:27 PM
Rob Raymer's Avatar
Exclamation QMP Turbo Formula - 750rwhp / 830rwtq STOCK ENGINE
Well, we may now be able to put a few theories to rest. Since so many of you want to see the Formula run with the stock engine, I decided to strap it down to the dyno tonight and go for broke.
This time however, I filled the tank with Turbo Blue 104 octane race gas. Kept the alcohol injection in place, and added a lb of boost (now set at 12lbs). After adding a bit of fuel to the programming as a precaution, we made the first pull through the full dynomax exhaust. I was stoked! It made 633rwhp/767rwtq! You can barely even hear the car running through this exhaust!!!
So next, we opened up the QTP electric cut-out. It then made 691rwhp/787rwtq with an AF maxing out at 12.5:1. (yes, lean but we had to start somewhere)
So we added more fuel to the tuning and reset the dyno: This time when it reached full boost, it spun the tires on the dyno and still made 713rwhp/831rwtq w/AF peaking at 12.1:1! Un-friggin-believeable! With a completely stock 124,000 mile engine! Through our standard, un-modified turbo kit!
I decided to give it one more go....this time with an extra lb of boost. So we moved the car back on the dyno a bit at DynoJet's suggestion to try and keep the tires planted (just plain BFG radials). Well, I was still getting used to calculating the electronic boost controller correctly, and apparently I was off. Boost went to 14.5lbs, it literally smoked the tires from 3800-5000, and put down 749rwhp!!!! If the tires had held, it would have made right at 800rwhp based on the missing area in the graph.
After a couple more failed attempts at getting the tires to stick, we gave up and called it a night. Next time, we'll have slicks on it.
I plan to post the graphs later tonight if I have time. FWIW, this thing made peak HP at 4500rpm's and stayed nearly flat all the way to 6200 where it was STILL making 660rwhp! Talk about a HP curve! And at 6000, TQ was still at nearly 600 ft lbs of torque! It's literally INSANE on the street.
As a recap: Still the stock engine, stock fuel rails, stock fuel lines, single Racetronix in-tank pump, standard QMP Turbo kit with standard intercooler, standard log manifold, crossover, wastegate, un-ported factory '02 passenger side manifold, etc, etc. All we have done is upgraded to the T76 Q trim with .96 AR housing, and spent a lot of time tuning it (112 dyno pulls now to be exact).
So, what's the record for highest HP stock engine?
Rob Raymer is offline
Old 01-22-2004, 07:30 PM
CHRISPY's Avatar
holy **** that is impressive!
Do you think it will hold together at the track with that tune or will you have to add even more fuel?
Amazing numbers!
CHRISPY is offline
Old 01-22-2004, 07:32 PM
Rob Raymer's Avatar
I think maybe it would. But who knows. Just for safety, I plan to add more fuel to the tuning and a Racetronix doublepumper first. At the track I'll run straight C16. Hopefully it'll make at least ONE good pass....
Old 01-22-2004, 07:33 PM
Coal Mining Director
onfire's Avatar
O I'd guess around 749...lol....what's the record for most dyno pulls???? sayyyyy 112...lol.......this makes 575 to 600 sorta lame if ya know what I mean
onfire is offline
Old 01-22-2004, 07:36 PM
squirrel masta's Avatar
Location: its as intense as the time i forgot how to sit down
rob is it taht 76 that makes all that power ,or do you think the 63 could make close to that
squirrel masta is offline
Old 01-22-2004, 07:41 PM
Adkoonerstrator
XLR8NSS's Avatar
WHOA!
So given enough octane and fuel I wonder what the limits of stock engine are? I'm sure at these levels it won't last long but, even a few pulls are impressive.
Damn..... :shaking head:
XLR8NSS is offline
Shorty Director
VINCE's Avatar
That's Insane!!!! It's still hard to believe. Is this still with LS1edit? What size injectors? Congrats!!!!
VINCE is offline
Old 01-22-2004, 07:43 PM
Scalpel's Avatar
Geezus-H-Christ, Rob you da' MAN! I need a turbo, lol
Scalpel is offline
Old 01-22-2004, 07:46 PM
rodent's Avatar
Rob, I need to personally come up there and buy you a beer man! Thats VERY impressive!!!
rodent is offline
Old 01-22-2004, 07:56 PM
frcefed98's Avatar
seems kinda pointless to be messing with this damn ATI kit of mine lol. Keep it together for the shootout. I really want to see that seasoned 125 thousand mile block make a run or two or three.... Great work Rob
J
frcefed98 is offline
Hardtop's Avatar
Damn I bet that thing is a handful on the street with cold roads and drag radials. I can't believe that motor is still in one piece. Un-friggin-real. Congrats.
Bruce
Hardtop is offline
Old 01-22-2004, 08:07 PM
Uthinkso's Avatar
Jesus Rob that is nuts!!
Any dyno video by chance? Can't wait to see the graph.
Uthinkso is offline
Old 01-22-2004, 08:12 PM
cablebandit's Avatar
yaaaayyyyyy.....finally we get to see what a REAL t-76 (and Robs kit) can do!!!!!!!!!
Is this still on the stock rear? People get amazed by that but on street tires it will NEVER get traction and the stock rear can last longer than on a stock car. Rob I think after all you have endured that you are entitled to gloat some and officially tell the naysayers about your kit to SUCK IT!!!!
cablebandit is offline
Old 01-22-2004, 08:44 PM
SScam68's Avatar
Damn!!
I think your going to break PSJ's heart
Great job!! Hopefully you'll be able to get 1 good clean pass before the car .
SScam68 is offline
Old 01-22-2004, 08:47 PM
NA$TY-TA's Avatar
Bruce
Awsome............
NA$TY-TA is offline
Old 01-22-2004, 09:01 PM
gator's 99TA's Avatar
simply amazing. simply amazing. i wish they were more affordable so we could see more hitting the track.
gator's 99TA is offline
Old 01-22-2004, 09:03 PM
blackz93's Avatar
thats unbelievable...wow!
i have alot of friends down here in nc that are going to the shootout that dont believe me when i tell them about your car, so plaese dont blow that fugger up now so everyone can see it!
blackz93 is offline
Old 01-22-2004, 09:04 PM
supersp0rt's Avatar
certainly a milestone in the ls1 world. keep it together for aat least one pass!
supersp0rt is offline
single digit dreamer
parish8's Avatar
what are you guys doing with your intercooler on the dyno? it's an air to air right? i wonder how much more power there is to be had with 100mph wind blowing thru that thing.
parish8 is offline
Old 01-22-2004, 09:21 PM
distortion_69's Avatar
WHAT?? No Nitrous.. grow some *****..
j/kin
distortion_69 is offline
Quick Reply: QMP Turbo Formula - 750rwhp / 830rwtq STOCK ENGINE
