Parts for SALE!!!!!!
Tremec T-56 out of 2004 GTO.........pending
Ram Clutch with pressure plate.........sold
SLP billet double roller timing chain......sold
SLP high volume oil pump........sold
Aluminum valve covers........sold
LS1/LS6 water pump........sold
C5 stock exhaust manifold pair........$75
Engine harness converted to stand alone..........sold
LQ4 bored .030 with rotating assembly "Balanced" 0 miles comes with
all the bearings and rings and arps studs..........sold
317 full port and polish by G&G Performance in Tomball comes with Patriot
dual valve springs rated at .660 lift with Ti retainers flow bench tested at 280cfm at .600 lift with stock valves..........sold
flywheel with stock clutch kit LS1/LS6......$75
factory camaro motor mounts with new bolts.......$75
