Massive Partout - Life Simplification Sale
OWN3D BY MY PROF!
Category: Audio/Video/Electronics
Price: $0
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird, Front wheel drive vehicles
Location (State): FL
Item Condition: Brand New
Engine: LS1/LS6
LS Engine?: Fits LS Engine
Helpful tips for potential buyers:
- All items are located in Jacksonville Beach, Fl 32250
- The price of the item unless stated does not include the price of shipping.
- On certain larger items I will not sell the item unless the fee for using paypal is paid for.
- Please do not send me an offer of $20 on something that I am selling for $20 and is going to cost me $25 to ship.
- I’ve bought and sold a ton of things on here. I am reasonable, but do not lowball me or say what is your bottom dollar? The price listed is the price of the item. If you’d like more information, other pictures, or anything else let me know, and I will do my best.
I'm going to keep the descriptions short on this as there's a ton of items being listed:
3. Stock intake manifold gaskets for LS1/6 intakes (I believe). My Price = $10
5. 2x 94+ LT1 Throttle bodies. My Price = $10 EACH
6. 2000 Front spindles, brake rotors, calipers, and upper a arms. Stock parts that would be good for a LS front brake swap. My Price = $200
8. Front half of a 5177 kit with purge solenoid, 100 jets, and some wiring. My Price = $150
10. Dart 221.5cc ported heads, 62.8cc chambers, 2.055 / 1.60s. NO SPRINGS. These started life as Dart 205cc casting heads that were ported, opened up the chambers, and had a valve job performed. They are a very nice set of heads that flow as such on a 4'' bore and 1-7/8ths pipe attached:
LIFT....INTAKE...EXHAUST
.200.....144.2......123.0....
.300.....210.5......178.3....
.400.....258.2......216.4....
.500.....298.3......230.3....
.550.....313.7......240.7....
.600.....320.0......244.4....
.650.....325.7......242.5....
I also spent a lot of time measuring the valve drop on these which comes out to:
Intake .153
Exhaust .195
These will need to have around a .005 clean up mill done to them as they were roughed up a little by my floor when I was removing the springs. My Price = $1200
11. Yella Terra cathedral port rockers. These are the nonadjustable 1.7 ratio ones. I bought these on black Friday of 07 or 08 and they have been sitting in the OEM packaging ever since. My Price = $390
13. Xceldyne 7mm, 1.60, 5.585 Titanium exhaust valves. Used from a set of SB2.2 Heads. My Price = $50
14. Manley 7mm, 2.175, 5.850 Titanium intake valves. Used from a set of SB2.2 Heads. My Price = $70
16. AFR 8109 1.540 springs, spring bases, and shims. These have been oiled, but never run. My Price = $145
Part Number - Size - Pressure - Material - Coil Bind - Rate - Max. Recom.
Lift
AFR-8000 - 1.540 OD, .800 ID - 225# @ 1.950, 600# @ 1.250 - Chrome Silicon - 1.155 - 550 - .710
These are not drop in springs for stock heads. This is a comparison shot to a Patriot extreme gold .660 lift spring.
18. 2’’ Kooks stainless steel headers with 3.5'' collectors. Used with discoloring. There are a couple of small dings on the bottom. See the pictures below. The damage is very minute. My Price = $700 Shipped
Flanges = Perfect
http://img46.imageshack.us/img46/483/kooksone.jpg
http://img834.imageshack.us/img834/439/kookstwo.jpg
Header One
http://img819.imageshack.us/img819/8822/kooksthree.jpg
http://img137.imageshack.us/img137/7688/kooksfour.jpg
Header Two
http://img440.imageshack.us/img440/1259/kooksfive.jpg
http://img840.imageshack.us/img840/5596/kookssix.jpg
21. Forced Inductions S95, good for 1800-1900hp. It has a 1.00 undivided AR. I bought this from Phil99Vette a while ago. It came off of his stock suspension drag radial car. The turbo has never generated boost and seen perhaps less than a mile of street driving. It has been camping out in my garage ever since. My Price = $1200 Shipped
24. 8x dry nozzles. NOS blue nozzles. My Price = $60
29. Black Jegs DSSL. For 3rd and 4th gen Fbodies. My Price = $25
30. Stock automatic transmission mount. From a 96 LT1 camaro. My Price = $10
31. Stock automatic shifter and 96 TA ****. My Price = $20
32. 93 Driver and Passenger airbags. My Price = $20 EACH
34. 2000 Camaro hardtop weather stripping. I was planning on swapping this onto my 93, but never got to it. My Price = $100
35. 2000 Camaro gauge bezel. My Price = $10
36. 2000 Camaro glove box. My Price = $10
37. 2000 Camaro Panel under the steering column. My Price = $10
38. Black flat trans am hood. Has a couple rock chips, but is free of any dents. My Price = $60
39. 4x 95 Camaro salad shooters, center caps, and slashed tires. This is the only picture I have of them. My Price = $60 or $15 EACH
OWN3D BY MY PROF!
SOLD ITEMS
- 4x 4 in 1 out NOS distribution blocks. SOLD
- Super Vic and fuel rails = SOLD
- 7.350ish pushrods (roughly measured) = SOLD
- SLP Lid. SOLD
- 3 to 4 inch Y pipe for QTP headers with a flowmaster merge SOLD
- Quad CME tip. OEM SLP. SOLD
- FAST 90mm intake manifold and valley cover bolts = SOLD
- Jesel solid lifters. Part numbers LFD-44003L and LFD-44003R. = SOLD
- 2x 255lph fuel pumps. = SOLD
- GM / Motive 10 bolt, 3 Series 3.73 gears, 3 quarts of redline gear oil, posi additive, and installation kit. = SOLD
- 10 bolt TA rear end cover. BNIB = SOLD
- Used .650 lift spring set = SOLD
- Ebony T top a pillar and latch covers. = SOLD
- Stock LS1 fuel rail. SOLD
- 4an feed line. SOLD
- Moser 9’’ housing = SOLD
- 8x wet nozzles. 7 brass, 1 aluminum = SOLD
This will be kept as current as I can keep it.
- SLP Lid. SOLD
OWN3D BY MY PROF!
I'm not going to split them up.
I think I may actually have an extra shifter cable with the bracket. It came off of a transmission I bought a long time ago. If you can show me a picture of what you're looking for I can let you know.
I've received a ton of messages and I'm doing my best to get back to them. Responses will be given out triage style to the ones that require the least amount of time.
I dont have a picture of it, but its what the trans end of the shifter cable connects to. The end of the cable "pops" onto this and its held to the trans by a 15 mm bolt IIRC
OWN3D BY MY PROF!
The 4x NOS distribution blocks and Super Vic with fuel rails have been sold. The thread has been updated to reflect this.
Sorry, I have the cable, but not the transmission bracket.
Damn Bro... when I seen this I was like NO WAY!!! I thought you were killing your projects, but then I read your intro, lol...
I would LOVE to have the Moser rear, I want a narrowed rear but I have the MWC FAB9 still sitting purrdy in the box. Gl with the sale Bro!
DM
DM
OWN3D BY MY PROF!
PM headed your way.
I'm only killing one as I don't have the time nor money to finish it. Its also taking away from my ability to work on my Formula. I'd definetly prefer to sell the moser housing locally. It saves me all of the effort of having to strap it down, borrowing someone's car, and driving all the way across town to a freight depo.
I would need your zip code. That's also something I'm not flexing on the price about. The price is listed + shipping + 3% for paypal fees.
Yes, you could as there's a buffer built into them. One spring is different and I hope you read that. The price shipping so close in state would only be + $8.95 for the flat rate priority mail box and you would have them in two days.
DM
DM
Hmmm... Maybe we can trade on my MWC Fab9 + cash for the Moser... My setup is still sitting in the crate like the day I got it from Eric, ie; brand spank'n new
I'll give it some thought, but let me know what you think. I really want to run 15x15 rims on my Bird.
DM
DM
OWN3D BY MY PROF!
SLP lid, 3 --> 4 y pipe, and SLP CME tip sold. Everything else is still available. If the item is not under the list of items that says, "SOLD ITEMS" in bold, italic, and underlined text it is still for sale.
12. Jesel solid lifters. Oiled and never run. The best drop in lifter out there. Part numbers LFD-44003L and LFD-44003R. .842 body diameter with a .760 diameter roller wheel. These weigh a scant 84 grams each and cost $167 a piece from Jesel. My Price = $550 shipped
I will take these lifters. Please PM me your Paypal account info and I will send you the money.
I don't see them in the picture, but do they have the dogbone retainer kit with them also?
