UPDATE...NEW LOWER PRICE ON PISTONS and brand new cam Ls 408 long block part out!!!!!
Price: $0
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO
Location (State): TX
Item Condition: Used
Engine: LS1/LS6, Small Block
LS Engine?: Fits LS Engine
These heads have brand spanking new LS7 lifters, 5/16 dual walled chrome molley pushrods and ARP head bolts!! I just put it all together last Saturday!!
I also have another cam that I purchased for his motor but I did it before I decided to make the change to solid!! Here are the specs!
Comp cam: 113+4 LSA 680/680 Lift and a 254/271 Duration!! This cam is brand new and not even out of the box!! Still in its original packaging!!
Check this photo link to my photobucket to check out all the pics of the motor!!
http://s221.photobucket.com/albums/dd16/hantzum/Camaro/
THE HARMONIC BALANCER IS NOT INCLUDED!!!
EVERY SINGLE PART IN THIS MOTOR WAS PURCHASED BRAND NEW!!!
Bottom END
Diamond Racing Forged Piston Set: 4.030 Bore, 4.000 Stroke,
Reverse Dome Diamond Forged piston 8cc
AFR Exclusive Total Seal Piston Ring
Set: 4.015, 1.5mm/1.5mm/3.0mm, 200 plus 25 shipping for the whole piston set not including connecting rods Pistons sold
TOP END
ARP head bolts 75 plus 5 dollars shipped SOLD
LS7 lifters- SOLD
Custom Cams Comp cams cam shaft V2 LS1 Camshaft 248/254 .617/.612 114+4 LSA SOLD
Arp cam bolts and retainer bolts included with cam
F.A.S.T. LSX Composite Intake Manifold 500 plus 25 shipped SALE PENDING
90 PTM 102mm Throttle Body, to Fit F.A.S.T. 90mm Intake Manifold
FAST 90mm/ PTM 102mm TB 150 plus 20 shipped SALE PENDING
PRC Stage 3 LS6 Cylinder Heads 335CFM at .650 lift SOLD
New GM LS6 Castings Outright, LS9 7 layer head gaskets 75 plus 5 dollars shipped
PRC 5/16 Dual walled chrome molley pushrods
LS1 roller rockers
PRC .650 spring set all included with heads SOLD
11.5:1 comp
This motor has about 5 TOTAL miles on it, YES ONLY 5 MILES, it has been trailered everywhere and the only street miles it has is the the time it takes to back the car onto the asphalt and pull it into the trailer!!as I built it for street use but decided to go all drag with it!! This motor has 22 passes on it with a 2 stage 300 shot!! This motor dynoed at 550HP NA on a power glide and slicks with a PTC 5500 converter!! Its best pass was a 6.14 at 115MPH in the 1/8 at 6400 DA! Who knows what this thing would have run at sea level!! As you can see the bottom end is in perfect condition, when I pulled the heads there was only carbon on the pistons with absolutely no detonation marks!!! This motor is as healthy as it was brand new!!
I replaced the lifters to brand new LS7 ones, new chrome molley dual walled 5/16 push rods and reset the springs!
Below are a couple of video link to the car and tons of pics!! PM me with any questions, I receive those quicker than an actual thread post!!!
There a ton of races from other cars on this video, I couldn't crop it down! Fast forward to exactly 4:00 minutes and you will see the last pass as of July 24th 2010
http://www.youtube.com/watch?v=3f689...layer_embedded
I seen where you said you wasn't selling the block or anything with the bottom end.
I am in the process of building a 408 myself. I already have my rotating assembly but no block yet.
interested in doing something?
also what about the LS7 lifters?
Let me know what you want to do!!
Note with these heads you are getting the springs roller rockers and push rods!!
I will do 650 for the heads and 750 for the heads and cam if you buy them together plus 35 bucks shipping!!
There seems to have been some confusion on the FAST intake and throttle body!! To clear it up!!
The FAST intake I will sell for 625 bucks! If you buy the throttle body with it I will do it for 750!! plus 20 bucks shipping!!
yes retainers are titanium!! pushrods are 5/16 dual walled but I am only selling those with the heads!! I just put them on the heads and reset the spring height and Im not going to take them all back off again!!
