Parting out '99 Trans Am, billet shift knob, B&M Ripper shifter, much more
Category: Interior
Price: $25
Location (State): KS
Item Condition: Used
Engine: LS1/LS6, LT1/LT4
LS Engine?: Fits LS Engine
Passenger's side (RH) door $100
Driver's and passenger's airbags with sensor $100/pair
Headlight switch $10
Body control module $20
Radio & HVAC bezel / trim $10
Door panels (gray leather) and plastic door panel trim/inserts $100/pair
Dome light $10
Gray headliner for T-top car $50
Gray interior trim panels beside rear seat - $20 each side
Gray interior trim panels alongside hatch area - $20 each side
Gray kick panels $15 each side
Gray tilt/cruise steering column and steering wheel $75
Gray dash $100
Trans Am instrument cluster $50
Factory jack $10
Gray flap/cover for storage well in hatch $10
"WS6" engraved billet shift **** for 6-speed trans $20 - SOLD
B&M Ripper shifter for T56 6-speed trans, missing 4 oval washers $80 - SOLD
Passenger's (RH) side-skirt / ground effect $30 - SOLD
2 - 16" Trans Am chrome wheels, some chrome peeling on back, front looks great $50/pair - SOLD
Monsoon cassette player $10 - SOLD
Both T-tops, T-top weatherstrip, T-top hardware/fasteners, black roof panel between t-tops - $125 - SOLD
If you purchase multiple items, I might be able to make you a deal.
Last edited by kst8engineer; Oct 12, 2010 at 12:41 PM. Reason: added wheels to list
Can I get pics of the Shifter to Nsty98ta@aol.com, are the washers for the mounting bolts? also I am looking for the upper and lower radiator baffling if you have it and the vacuum canister and line that was mounted under the passenger side frame rail in the front.
Brian
Brian
Pics sent. Yes, the four washers are for the mounting bolts. Sorry, but the baffling and vacuum canister are gone.
Brian
Brian
I have a 98 Z28 M6, and i'm looking for the black leather boot assembly for the shifter. My plastic frame piece broke and now its flapping all over the place. Also looking for the plastic piece for the window, side-mirrors,and lock controls, mine are bent/broken. Also need sun-visors!
The dash is in good shape -- no cracks. The only piece I don't have is the hard plastic piece that goes on top, between the dash and the windshield. I don't know that I have the whole wiring harness intact, but if you wanted the instrument cluster for $50, I'll include the pigtail connection for the cluster. For the dash wiring, I probably have most or all of the connectors, I just don't know if the whole harness is intact or not without some investigation.
