F body Parts for sale:MD: 35th LE wheels, Borla CB, SLP lid, Ls6 intake etc...
Old Sep 19, 2010 | 09:48 PM
MATTREDSS's Avatar
Default F body Parts for sale:MD: 35th LE wheels, Borla CB, SLP lid, Ls6 intake etc...
Ok I have decide to sell a couple things I'm no longer going to need or have use for. Will be adding more things as I go. I will add pics when I'm able to get some free time either this week or up coming weekend. Located in southern MD. Also I may be interested in trades, some things I am looking for are LCA relocation brackets, anti roll/drag bar, drive shaft safety loop, fast toys 85-104mm lid, nitrous bottle heater, remote bottle opener, higher volume fuel pump(walbro or racetronix), Fast 90-92 intake and throttle body or Edelbrock Victor jr with elbow, fuel rails and throttle body..... Also looking for ARP (new) head bolts or studs, ARP (new) Rod bolts, Yella Terra 1.7 rockers, Cometic (new).040 head gaskets, lmk what you have.
FTI Converters 4200-4400rpm ls1 stall, went multiple 1.4xx 60fts with this converter on a 17inch drag radial $SOLD
QA1 F series front shocks/coilovers $SOLD
QA1 front 300lb springs $SOLD
SLP 01-02 85mm MAF: Descreened with 3-5 wire adapter $SOLD
SLP smooth bellow $SOLD
2002 35th Annversary LE SS Wheels (2); Tires not included $SOLD
Stock rockers have 60k miles on them, extra set I have laying around.Includes rockers,bolts and mounts/pedestals $SOLD
Fast Toys Ram Air set up, keeps AC $SOLD
4l60e $SOLD
SLP Blackwing Lid $SOLD
Stock ls1 f-body dual radiator fans $SOLD
Stock 241 casting LS1 5.7 cylinder heads, 62k miles on them. Includes eveything minus valve springs $SOLD
LS6 intake manifold ported and smoothed by Cartek, also includes 00-02 throttle body ported by Cartek as well $SOLD
HSW 78mm N20 plate for wet system $SOLD
35th LE SS wheels. I do have tires mounted on them currently, if your interested with tires let me know can negotiate a price. Sumitomo HT3 275/40/17 fronts and MH Race Master 275/50/17 drag radials rears. I will have some pics of the drag radials in little bit. Small rash spot on one front wheel, 2-3in max. $SOLD
Stock LS1 rockers, have 62k miles on them. Includes mounts/pedalstals, bolts and rockers $75
Borla adjustable cat back, quad tip 98-02 LS1 f-body $400/obo
4L60e trans set up/parts: Will seperate parts, let me know what your interested in or need $MAKE OFFER
All other parts I have 4l60e related are listed below:
* stock aluminum drive shaft 4l60e to 10bolt
* stock trans cross member
* stock shifter and cables
* stock converter
* dip stick
Parts below I am listing for a couple friends, so if your interested let me know I can pm you there number so you can talk to them.
SLP ram air $make offer
TCI LT1 4l60e converter 4200rpm stall, less than 100miles on it and no track passes $150
Caspers Electronics Fan control module. Never been used, just opened up bag to look at and thats it $40
Accu Fab 98-99 80mm throttle body $150
Ls6 cam, pushrods and valve springs $350/obo
T56 6speed transmission $1000; with Zoom twin disc clutch $1300
Old Sep 20, 2010 | 03:14 PM
transamsam98's Avatar
great seller buy with confidence fellas
Old Sep 20, 2010 | 08:32 PM
02BLKWS6MD's Avatar
agreed with the above statement
Old Oct 3, 2010 | 08:22 PM
MATTREDSS's Avatar
^^^^^Thanks Sam and Will
FTI converter, QA1 coilovers, and 300lb springs all sold locally. TTT.....more things added. more pics will be added shortly
Old Oct 6, 2010 | 03:58 PM
MATTREDSS's Avatar
bump......ttt
Old Oct 9, 2010 | 09:42 AM
1SweetSS's Avatar
i'm interested in the Fast Toys Ram Air set up if you still have it
Old Oct 9, 2010 | 06:41 PM
MATTREDSS's Avatar
Ok cool, yes I still have it
Old Oct 9, 2010 | 07:06 PM
1SweetSS's Avatar
where are you located and when is good to pick it up ?
Old Oct 9, 2010 | 07:44 PM
MATTREDSS's Avatar
St. Marys city/ Lexington Park, about 30min farther south of MIR. I'm in ocean city right now, I will be back Monday. Any day is good for me, just let me know.
Old Oct 10, 2010 | 07:05 AM
Nextinstant39's Avatar
Sent you a pm about the TB....
Old Oct 12, 2010 | 10:24 PM
MATTREDSS's Avatar
All pm's replied to, Some things added. Bump it up to the top.
Old Oct 13, 2010 | 12:05 PM
pboxfun's Avatar
pm you
Old Oct 13, 2010 | 09:44 PM
MATTREDSS's Avatar
all pm's replied......ttt
Old Oct 16, 2010 | 12:49 PM
MATTREDSS's Avatar
bump...
Old Oct 18, 2010 | 01:20 PM
MATTREDSS's Avatar
Bump.....to the top. some pics added
Old Oct 18, 2010 | 11:28 PM
taman86's Avatar
where would you be able to get a coupler for the black wing?
Old Oct 19, 2010 | 05:58 AM
MATTREDSS's Avatar
I believe slp, the orginal coupler tore.
Old Oct 20, 2010 | 02:39 PM
MATTREDSS's Avatar
bump it up...pm's replied to
Old Oct 23, 2010 | 11:43 AM
MATTREDSS's Avatar
bump it up
Old Oct 25, 2010 | 10:47 AM
MATTREDSS's Avatar
all pms replied to... bump it up
