New Products Showcase Come inside to see the newest hardware!
UMI New Product Release- 2010-11 Camaro/2008-09 G8 Rear Toe Rods
Old Sep 21, 2010 | 09:44 AM
UMI Performance's Avatar
Talking UMI New Product Release- 2010-11 Camaro/2008-09 G8 Rear Toe Rods
2010-2011 Camaro/2008-2009 Pontiac G8 Rear Toe Rods
Application:
2010-2011 Chevrolet Camaro (All Models)
2008-2009 Pontiac G8 (All Models)
#2520- Polyurethane busings- $119.99
#2521- Roto-Joints- $194.99
The rear toe rods control the camber alignment of the rear end preventing the tire from moving inward or outward during suspension load. The factory toe rods are made from flimsy stamped steel and feature soft rubber bushings causing deflection which leads to erratic handling, poor traction and possible rear tire wear. Replacing the factory arms with heavy duty toe rods makes for a more stable suspension, improved traction and better braking. The UMI toe rod arms are manufactured from 1” x 2” rectangular tubing and fully TIG welded for the utmost in strength. They are assembled with fluted, greaseable and low deflection polyurethane bushings from Energy Suspension or can be purchased with UMI's Roto-Joint. Toe rods are a direct bolt in and installation time is less than an hour using basic hand tools.
Part # 2520- Polyurethane Bushings- $119.99
Part # 2521- Roto-Joints- $194.99
