Ls2 4.000" Forged Pistons/Rods, Hell Fire Rings, Hawk Pads, Calipers, Rotors, Etc !!!
Category: Engine - Power Adders
Price: $300
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): FL
Item Condition: Used
LS Engine?: Fits LS Engine
Also look at My Sig for the links to the rest of my Sales !!!
Prices are plus shipping and 3% Paypal.
JE Pistons (Custom Made) w/Pins, Locks and used Rings
4.000 Bore
1.314 Comp. Dist
15 degre Valve Angle
.927 pins
6.125 Rod
3.625 Stroke
They were almost $800 new - SOLD !!!
Eagle 4340 Forged H-Rod - SOLD !!!
New set of HellFire Rings for 3.905 File-Fit - SOLD !!!
Part# R19114 38MM
Ring thicknesses -
1.5MM Top
1.5MM Second
3.0MM Oil
Hell Fire® Rings
Speed-Pro Hell Fire rings, manufactured from a specially hardened and tempered ductile iron alloy, are engineered to thrive in extreme racing conditions.
These rings retain tension under the most brutal operating conditions, including engines that rely on megadoses of nitrous oxide. Proven in Pro Street, IHRA Pro-Mod and NHRA Top Fuel & Funny Car racing, Hell Fire rings will not flake, and the SS-50® oil rings keep chambers dry, preventing detonation.
LS2/LQ9 Pistons Full Floating Pins (Only few left ) - $29 Each !!!
LS2/LQ9 Rods (Full Floating Pins - Only few Left) - $25 each!!!
Motor Mounts (Ready for Poly Mounts) - $SOLD !!!
LS1/LS6 Piston/Rod Low miles - $25 each !!!
LS6 Thermostat - $18 !!!
Poly Bump Stops NEW (Bought from a member here but never install them) - $48 !!!
Brand New Mr. Gasket Exhaust Gaskets Ultra Seal for LS1/LS6/LQ9/LS2/Etc - $19 !!! (I paid almost $35 for them...)
LS1 Coils - $18 each !!!
97-08 Corvette and 05-06 GTO Front Hawk Pads NEW (HB247F.575) - Only $99 and FREE Shipping!!!
SLP **** - $45
O2 Sensor "AC AFS 98" 16" long - $28 Each
a
O2 Sensor "AC AFS 97" 12" long - $24 Each
A/C Evaporator - $25
Accessories and A/C Belts Low Miles - $29
Stock SS Tailpipes / Tips - $34 !!!
LS1 Intake with Plug - SOLD !!!
EGR Pump and Lines - $55
AIR System Pump and Hoses - Make an offer !!!
SLP **** - $45
a
LS1 Front Calipers $89 - "Rear SOLD"
Package Deal = Front Calipers, Front Rotors and Front Pads - $169 !!!!
Grinded LS1 Front Calipers (To Clear Drag Wheels) - $100 !!!
Stock Font Pads (tons of life left) $40
Set of GM Camaro LS1 Rotors "READY TO USE" Front or Rear $69 each set "FREE SHIPPING"
LS1 Roller Rockers - $7 each
Oil Pan Tray - $15
Radiator Hoses - $9 Each (lONG SOLD)
Throttle Position Controller / Sensor (GM 10426909) - $69
Brake Hoses $18
Brake Master Cylinder $40
Brake Lines from Master to the Block - $15 each
ABS Brake Block - $50
Cruise Control Module - $79
10 Housing with Relocation Brackets Weld in - SOLD !!!
10 Bolt C-Claps Axel holders $12
LT1 Front Calipers RED with CAMARO on them - $55
LT1 Performance Pads - $38
Front Drilled LT1 Rotors - $60
LT1 Spindles - $40 Each
Oil Pan Tray - $15
Brake Hoses $18
