I suppose its time to make a build thread...truck manifolds!
Old 10-03-2010, 05:01 PM
XtremeDime's Avatar
Default I suppose its time to make a build thread...truck manifolds!
This is my 2nd leap into the FI world, last year it was with an ebay kit which can be seen here https://ls1tech.com/forums/forced-in...-ebay-kit.html
Here was the build specs from last year.
Stock block
Stock rear
6 speed(stock clutch for some, tex oz for other)
317s w/ls6 yellows and hardened pushrods
Ebay hotside
Masterpower T70 .96 a/r
Tial 38mm WG
Custom coldside
Mishimoto IC
SteedSpeed inline BOV
Stock suspension
I put down 485hp/492tq on the dyno at 8psi, through the stock clutch which did not make it all the way through the dyno session. I believe I could have made over 500 with the new clutch and a little more tuning. At the track the best time I could get was 12.3 w/2.14 60' and 122mph ET, on street tires.
This year's build:
Stock block
Strange S60 w/3.54s
MT ET Streets (26" or 28" tall, still deciding)
6 speed(Same Textralia, but Im debating on twin disc)
317s, light port and polish @ home
ARP head bolts(not studs, yet)
Griffin radiator 25241
Pat G custom turbo cam
Truck manifold setup, turbo located in battery area
Precision 76mm .96a/r
Turbonetics 42mm deltagate
Custom cold side
Mishimoto IC
BOV(still undecided but I was pleased with the inline BOV)
Methanol injection
UMI DA LCAs
UMI DA PHB
UMI 3 point SFCs
UMI Tunnel mounted TA w/DS loop
Still need to sort out springs/shocks
SJM ABS Delete w/Line lock
Im shooting for 600whp @10psi, and Ill be pushing the limits of the stock motor. Im hoping to pull off some mid 10s with some decent 60' times.
Pics to come.
Old 10-03-2010, 05:09 PM
MUSTANGBRKR02's Avatar
Good luck on this one. I am starting my build on my buddies car aswell, I just got my TIG welder in the other day.
XtremeDime's Avatar
Heres how it looked at the beginning(Mid-Sept)
After a couple hours of work
The Precision 76 next to the MP T70
Heres how the heads looked when I pulled em off
Old 10-03-2010, 05:11 PM
XtremeDime's Avatar
After some work on the heads this what I got:
Im polishing the CC mainly. I cut the machined lip down on the intake bowl, and I will be port/polishing the exhaust port. I did very little work on the intake side of things because I didnt want to mess up my flow too bad.
Old 10-03-2010, 05:13 PM
XtremeDime's Avatar
Blower box removal, I bought a piece of steel for 15$ and made my own delete plate
Wire tuck
Old 10-03-2010, 05:16 PM
XtremeDime's Avatar
Doing some mock up for turbo placement:
Mock up for the fans on the radiator, then I realized I bought the wrong size radiator FML
First UMI parts came in:
Wastegate came in:
Old 10-03-2010, 05:23 PM
XtremeDime's Avatar
Pretty much just waiting for more funds at this point. A board member bought my old turbo kit and has been paying in payments. Also we are getting our dividend checks on Thursday(gotta love Alaska) so I will have about 2500 to play with. Heres my list of parts that Im ordering:
UMI TA w/DS loop
UMI SFCs
Strange DS
Pat G Custom cam
Pushrods
BOV
IC
Ive already bought a welder but Im still waiting on it to be delivered. I dont have any experience welding so Im alotting myself a good chunk of time to get it down before attempting to weld on my car. After I get decent at it, Ill order my flanges and piping.
Old 10-03-2010, 07:22 PM
Restricted User
1BAD_LS1's Avatar
Off to a good start! Im still not sure what im gonna do on my build...... so undecided lol!
Budget will play a big part in my build as im looking at another house!
Keep us updated! Get in alot of practice with that welder (and i know its expensive but get some argon for it)!
Old 10-03-2010, 07:24 PM
Restricted User
1BAD_LS1's Avatar
Is it just me or does something look fishy in this picture?????
Old 10-03-2010, 07:42 PM
XtremeDime's Avatar
Eh? What do you mean?
Old 10-03-2010, 07:51 PM
Restricted User
1BAD_LS1's Avatar
I got ya.. thats a little bit of oil in the cylinder...... hahahaha my bad. I glanced at it earlier had me a little concerned!
Old 10-03-2010, 07:54 PM
JAX04's Avatar
just looks like some fluid on the piston to me, if thats what your referring to.
OP, great start man, best of luck this time!!
Edit, as i as typing lol, sorry,
Old 10-03-2010, 08:03 PM
Ws6kid.'s Avatar
looks good!
Old 10-03-2010, 08:38 PM
BottleFedZ346's Avatar
Looks good man car should deff. be a stout ride!
Old 10-03-2010, 08:41 PM
XtremeDime's Avatar
Thanks all!
If anyone has some used parts heres what Im lookin for:
UMI TA w/DS loop
Hotchkis STB
Coil relocation kits/brackets
Old 10-03-2010, 10:08 PM
NightHawk's Avatar
lmao @ title
Good luck with it bro!
Old 10-03-2010, 10:55 PM
Frost's Avatar
Time to ditch that six speed for that mid 10 on turbo. You won't get the 60' you need without a two step, and your trans won't live long WITH one.
Old 10-03-2010, 11:19 PM
XtremeDime's Avatar
I might get a 2 step depending on how the $$ is looking.
Ready to do my base tune?
Old 10-04-2010, 06:36 PM
XtremeDime's Avatar
Got my radiator in today.
Old 10-04-2010, 07:19 PM
do the auto swap!!
Quick Reply: I suppose its time to make a build thread...truck manifolds!
