Gears, Differential, BBK, Stainless Tips, Aluminum Elbow, Stock Parts, Gauges
Category: Accessories
Price: $1
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette
Location (State): WI
Item Condition: Used
Engine: LS1/LS6, LT1/LT4
LS Engine?: Non-LS Part
58mm BBK Throttle Body, Chrome powder coated w/ new TPS and custom IAC. Barely used - Finally SOLD
Stainless Steel (z28) style exhaust tips. I've seen them online for around 50$ - Asking 30$
Aluminum LT1 intake elbow. Only has one coupler. Great shape - SOLD
Autometer Voltage gauge. Actually is an OEM Mercury Marauder gauge - 35$
Brand new Glowshift Tinted 7 color Tachometer. Missing the wiring harness that plugs into the back. Costs 5$ to replace from Glowshift. SOLD
Brand new LT1 Accessory Bracket powder coated bright red - SOLD
Brand new Indiglo style LT1 gauge overlay - you will need to buy the power inverter (super cheap) for this to work - SOLD
Stock (Auburn?) Posi differential with 323 gears, working great when pulled to upgrade to 373's - SOLD
Stock throttle body 93 z28 w/ black Z28 plate - 40$
Headlight switch assembly from a 93 z28 - 10$
HVAC ***** from a 93 z28 - 10$
Optispark harness from a 93 z28 - 10$
93 z28 Bad Optispark, use for experiments or something, idk (bearing is bad) - 10$
OEM DeCarbon shocks/struts from a 93 z28 w/ 84k miles. Felt great, replaced them with KYB AGX's when I lowered the car - 40$
Stock Springs 93 z28 - 30$
Stock air intake tube - 5$
Stock 93 z28 Fuel Injectors (8) - SOLD
Stock 93 z28 Ignition Coil - 10$
Lot's more, will update the list as I find more stuff!
