burkhart, afco,madmanPHB,OFI 85mm kit,370cid,bs3,th400,lsx427, 106mm turbo
Category: Audio/Video/Electronics
Price: $0
Location (State): LA
Item Condition: Brand New
LS Engine?: Non-LS Part
intercooler nitrous spray kit main feed line new, intercooler spray bar new solenoid new 200 will include free with purchase of turbo
LQ 9 short block balanced and assembled; sold
Block bored .010 over stock crank cut .010 main and rods clevete bearings
Melling high volume oil pump
Mahle pistons coated dished
Scat connecting rods 4340 6.125 floating pin
Comp Cam (CC) cam shaft custom ground blower, Solid roller lift 647in/640ex duration over .050 242in/236ex 3500
new CC solid rollers and CC roller rockers 1.72, CC 7.4 Harden push rods pwr steering alt i will include ac comp as well
3500 for 370 with everything included above or 3k with no lifters cam or valvetrain OBO
madman torque arm bracket for 12 bolt $50
madman PHB coated red 115 sold
th400 new rev manual valvebody built to handle with trans brake 1000+ hp new 1000
persision industry shifter forward shift pattern new mounted will come with console lid 300
ls1 BS3 1700 sold
qtp electric cut out 3" used valve and switch only main wire can be obtained from qtp for 25-30 $100 sold
i am not responsible for paypal fees you can look at my feedback and buy with confidence you can send paypal as a gift to keep from paying fees, pay the fees or send check money order or any other form of payment
pics to come
427 lsx gm shortblock billet main caps priority main oiling 6 bolts per cylinder SOLD
callies dragonslayer 4340 forged 4.0 crank
oliver billet rods arp 7/16 bolts
wiseco 4.125 forged turbo pistons -32dish with heavy wall tool steel wrist pins .300 material above top ring land total seal stainless chrom rings for high heat applications clevite 2199 h main brgs with poly dyn coating clevite cb663 h rod brgs with poly dyn coating dura bond ch23 cam brgs arp main studs polydyne coating on pistons thermal coating on piston tops anti friction on skirts,
o ring block on 3axis cnc o rings included 1/2 head studs
cam motion solif roller cam(262/254@.050" 735/720 on 115lsa)
roll master double roller tinimg set with torington bearing and nitride gears
arp 2000 1/2"-7/17-8mm pro series 12pt head studs
melling 10296 coated high volume oil pump/ported pump
moroso lsx sheet metal oil pan with custom pick up tube with 2 turbo drain backs
ati sfi balancer arp ballancer bolt
gm ls2 front cover with cam sensor gasket seal and bolts
gm ls2 valley cover with bolts
LME custom oiling remote oil filter housing oil pressure regulator filters and fittings
as you can see the engine was built with only the best parts it is brand new never used to duplicate it would cost over 13k + build time
i would like to see $9500 shipped out the motor obo
106mm turbo kit designed by ky turbo forward manifolds all stainless turbo has dyno time only it is completely polished and cold side of turbo is v banded comes with a 5" down pipe with a vibrant "muffler" welded in to meet TRUE STREET classes has a brand new i will also include a 90mm v banded throttle body it has dyno time as well, 60mm JGS gate and has a used rechard racing intercooler purchased from FIREBALL which was on his 7 second ta looking for 7k for kit SOLD
burkhart chassis front bumper support coated metallic silver with afco radiator mezier remote water pump block fittings and custom crossover tubes comes with fan and shroud new 1200 SOLD
