Walbro intall for 99 and up.. Searched and cannot find.
#41
TT-TECH Veteran
I am not going to call it a "Hack Job" nor will I go on and talk about structural integrit when there are two frame rails one on each side so I don't think that was an issue. I only saw one coment on that and I would be willing to bet that the car had some prior damage from a wreck or lack of sub frame connectors or some thing along that line if what he said was true? I am not an expert on that although I have fixed several totaled Camaro's and have seen the wrinkles go a lot further than you would have thought. On another subject I looked at your web page and I did not see any pictures of your blower? I liked your shift light mounting place very stealth. That whisper exhaust looks a lot like a corsa, does is sound simular to one or what?
#42
I like the whisper. It actually sounds very similar to the Corsa. I think the corsa is a shade mellower in tone and loudness at idle and part throttle and a shade louder at WOT. But I have an electric cutout so i get mellow when I want it and loud and obnoxious too I like the Straight pipe slash cuts for Formulas and camaro's. They have a good side profile. If I had a T/A I'd probably go with fancy tips since you can't see the side anyways.
Mike
#43
Location: From the Bowels of Hell!!! You want some of me bitch?!?!?!
1 Post
Here's some pics of a 99 install I did. I'll upload the other pics in a sec.
VERY simple from the bottom. Screw cuttin' up a perfectly good car.
#46
No dont use tape. We just used the plastic connectors. No explosions yet. If I were to re-do it though I would have taken the time to solder it and use heat shrink.
#48
I just finished up doing the install on this and I must say it is pretty easy doing the access hole. Thanks to Chris99WS6PWTMET my cut was exact the first time. Thanks alot to all you guys who chimed in and posted the threads/pics in here.
#49
#50
The kit comes with butt connectors that you can use but its really easy to splice the wires. the stock ones are gray and black and the walbro harness will have red and black wires. Red goes to gray and black goes to black. I also bought a straight peice of fuel line instead of the formed one that comes with the kit, for me this made it much easier as the formed hose tried to compress the pump assembly alot. You'll see what I mean once you are in there. Other than that all the info is covered.
#51
#52
Sounds like an awesome setup Chris now I just have to worry about converting my system to the front mount regulator but hopefully I wont have to.
#53
Has anyone tried this yet?
http://www.thunderracing.com/index.c...t&contentid=79
A complete replacement for the 98-99 tanks with a new wiring harness.
#54
Thanks for all the good info I am putting a walbro 255 in my 2000 shitbox tomorrow. I had a feeling it was different from the 98's. Now I know for sure. Great info!
Brad
Brad
#55
#56
7 Second Club
Just my little writeup.
http://www.public.asu.edu/~nicolasd/
Go to performance, then scroll down until you see the fuel pump assembly picture.
#58
LS1TECH Sponsor
Brad
Brad
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
#59
Originally Posted by Racetronix
#60
LS1TECH Sponsor
Originally Posted by AgentOrange
That one pimp kit. A overkill for a 255 Walbro, but good for larger inline pumps.
__________________
>WEB SITE<
>WEB SITE<
