Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
FS: Tons of LT1 performance, N20 parts, and stock parts *Garage Clean Out*
Old Dec 22, 2010 | 01:30 AM
Tireburnin's Avatar
Default FS: Tons of LT1 performance, N20 parts, and stock parts *Garage Clean Out*
Category: Drivetrain
Price: $1
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette
Location (State): CA
Item Condition: Used
Engine: LT1/LT4
LS Engine?: Non-LS Part
Jimmy Jams n20 switch panel, stand alone n20 fuel system, fuel rail AN adapters, Simpson Camlock harness, spare tire bottle mount, ported maf, t-top holders, Dynotune digital WOT switch, ARP cam bolts, ARP flexplate bolts, stock electic fans, LT1 Heads w/ 987 springs, Borbet wheels and tires, New GM cat, etc
***All prices are OBO. PM or Post for Shipping Quotes***
10207643 Lt1 Heads with Bigger Springs/Retainers - $185 PLUS SHIPPINGThese heads are stock but have larger springs. These are the heads you want to use for after market porting through Ai or LE. I can't find the specs on the springs, but they were used with a GM847 cam with 1.6 rockers. Pictures show one valve not installed but thats because I took the picture before I finished putting them together.
Stock 97 LT1 Intake - $42 plus shipping
Stock except the throttle body bores are bored out for a larger throttle body.
Stock Lt1 Waterpump - $19 plus shipping
Lower miles at around 10k. Was working fine when removed.
EGR valves (I have a few of these in good condition) - $10 Plus Shipping
7.050 Comp Pushrods 5/16 - $25 Shipped
LT1 Electric Fans - $39 Plus Shipping
Stock LT1 Starter - $25 Plus Shipping
Stock LT1 MAF - $35 Plus Shipping
Holley HP150 Fuel Pump - $165 Plus Shipping
Holley HP150 fuel pump with about 20 hrs of run time on. This came off my Mustang and is being replaced with a much larger pump. No issues and limited street time on it. About 1 year old, but used mostly for a season of drag racing. Had a pre filter installed. $175
http://www.summitracing.com/parts/HLY-12-150/
Borbet Type M Wheels (17x9) with almost new Hankook tires - $420 Plus Shipping
***Willing to sep. wheels and tires - Wheels for $200 Plus Shipping***
Good condition with very little rash and the tires are almost new. I have a reciept from the tires and they were more than I am asking for wheels and tires. Wheels are silver painted with carbon fiber look center caps. They have a really nice offset and came off my old 95 Z28. Hankook Ventus 275/40/17 tires.
Positive wire cover from passenger area by battery (unbroken) - $7 plus shipping
This is pretty rare to find unbroken. It is the red positive break point near the battery.
Simpson Camlock Black Harness - $45 Plus Shipping
This harness is expired, but works fine. It is a camlock style from Simpson. Black straps. It is currently setup for a 4 point configuration, but the 5th point (crotch strap) is included. It came out of my corvette.
Brand new 93-95 GM Catalytic Converter - $199 Plus Shipping
This thing is brand new from GM. It lists for over $700 and I have a reciept showing it was well over $500 with a discount. This is a GM OEM part, not a cheap aftermarket cat.
(1) Nitto 555R 315/35/17 Drag Radial - $75 plus shipping
This tire has about 70% tread left. I got a hole in one and replaced both. This is the remaining good one. Plenty of tread left on it. Makes a great replacement for anyone that has damaged just one tire.
Ported and descreened MAF - $35 Plus Shipping
No issues with it. Came out of a 97 lt1 car.
___________________________________________
Racetronix 255 Fuel Pump and Hotwire Kit - $169 SHIPPED SOLD
This is a complete kit with about 1k miles on it. I was going to build a dual pump setup with it, but never got around to it. Worked great when removed. Includes the hotwire, relay and all pump/wiring. This kit is from a 97 F-body but may work for other years.
Proform Adjustable Shift Light - $30 Plus Shipping SOLD
I switched to an Autometer tach with a shift light and no longer need this shift light. It is adjustable for RPM on the back. Works fine and is black in color.
http://www.summitracing.com/parts/PRO-67005C/
Accel Coil and 95 ICM - $25 plus shipping SOLD
ARP LT1/SBC Flexplate Bolts - $16 Shipped SOLD
Includes 6 bolts from ARP. These were $27 new from summit. Swapped to an LS1 and have no use for them now.
ARP LT1 Cam Bolts (Incl. 3) - $5 plus shipping SOLD
LT1/TBI Air Foil -$11 Plus Shipping SOLD
Bolt in 10lb N20 Bottle bracket for spare tire well - $10 plus shipping SOLD
This bracket is made to bolt in the spare tire well. One side bolts to the rear trunk/frame area and the other slides over the antenna bracket. Securely holds a 10lb bottle hidden within the spare tire well.
Dynotune Digital WOT Switch - $30 SHIPPED SOLD
This splices in to your factory TPS sensor wiring and provides a signal to your nitrous setup. It avoids using a switch under the hood to tell when the throttle body is wide open.
7.20 Comp Pushrods - $25 Shipped SOLD
Russel LT1 Fuel Rail to AN Fittings (Feed & Return) - $18 Plus Shipping SOLD
These fittings are brand new in the box. Never opened them and they were $33 from Summit. These pop on an allow you to use braided supply lines and return lines. Part Numbers 640850 and 640860.
SJM 93-97 ABS Delete Kit with Line Lock (BRAND NEW) - $170 SHIPPED SOLD
This kit deletes the ABS block saving a bunch of weight and includes both the line lock and manual proportioning valve. It also has the optional double flare tool for installing the lines. This setup was $200 plus shipping when I bought it. The box was only opened for pictures and includes every line, fitting and electric connector.
Jimmy Jams N20 ash tray switch panel - $20 Plus Shipping SOLD
This is for a 93-96 manual center console and it has two arm, two heater, and two purge buttons. Fits great and works fine.
N20 Stand Alone Fuel System - $199 PLUS SHIPPING SOLD
This system was built similar to the method Reckless used for his f-body. It comes with a Jaz 1 gallon fuel cell. Includes a Holley Black pump which is more than enough pump to feed most engines, but could feed a huge nitrous hit. Uses 8an main lines and splits to -6/-4 for the fuel solenoids. It has an earls fuel filter and is plumbed for a return line. Also has a Holley regulator and summit fuel pressure gauge. Mounts in the front bumper support area and routes along the radiator support to the engine bay. The pump is $160 alone and there is tons of money in lines and fittings. The filter is $50 alone.
ProSystems/Holley Vacuum Operated Fuel Pressure Regulator - $79 Plus Shipping SOLD
This is Holley part number 12-704 and includes a vacuum port. It is brand new in the box and never used. It cost me $100 from Prosystems. Summit seems to have the same part number for $87, but it is not a vacumm referenced one. This is for carb pressure setups 4-10psi
Old Dec 22, 2010 | 01:00 PM
Tireburnin's Avatar
Added some parts
Old Dec 22, 2010 | 01:57 PM
VinR1's Avatar
what is the offset of the wheels and do you have a pic on the car? ...also, willing to separate wheels and tires?
Old Dec 22, 2010 | 02:16 PM
Fazz73jr's Avatar
Ill definitely be buying some stuff if you still have it after Xmas.
Old Dec 22, 2010 | 07:32 PM
Tireburnin's Avatar
Sending you a PM
Old Dec 22, 2010 | 11:22 PM
lethal bird's Avatar
What the price for the airfoil shipped to 39305.
Old Dec 23, 2010 | 10:51 AM
Tireburnin's Avatar
Bump for today
Old Dec 26, 2010 | 11:58 AM
Fazz73jr's Avatar
PM sent.
Old Dec 26, 2010 | 09:58 PM
Tireburnin's Avatar
All PMs responded to. Thanks
Old Dec 26, 2010 | 11:35 PM
Captain_Stabbin's Avatar
bump for ya
Old Dec 27, 2010 | 10:57 AM
Tireburnin's Avatar
Updated for sold parts
Old Dec 28, 2010 | 10:23 AM
Tireburnin's Avatar
Bump for today
Old Dec 28, 2010 | 11:33 PM
Tireburnin's Avatar
Bump for sold items
Old Dec 30, 2010 | 09:38 AM
djjab57's Avatar
bump for ya man, some good deals in here
Old Dec 30, 2010 | 10:15 AM
Tireburnin's Avatar
Thanks for the bump
Old Dec 30, 2010 | 09:10 PM
defaultexistence's Avatar
pm on heads
Old Jan 3, 2011 | 10:44 AM
Tireburnin's Avatar
Bump for today
All PMs replied to.
Old Jan 3, 2011 | 11:46 AM
SprayedLT1's Avatar
Can you please send pics of the starter to Firecop400@yahoo.com?
How many miles on it?
Old Jan 3, 2011 | 11:53 AM
Tireburnin's Avatar
I'll snap some pictures this evening. It has about 25k miles on it. Worked fine when removed.
Old Jan 3, 2011 | 10:13 PM
SprayedLT1's Avatar
Cool, thanks
